Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Technical and Specific Interest Nissan Discussion > Nissan Tires, Wheels, Brakes & Suspension
Google Links
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
View Poll Results: Which type of HP tires should I invest in?
Toyo Proxies (Specify what type of proxies in thread) 1 33.33%
Faulken 912 1 33.33%
Other (Specify in thread if you don't mind.) 1 33.33%
Voters: 3. You may not vote on this poll
Old 05-16-2008, 10:34 PM
madsen203's Avatar
madsen203 madsen203 is offline
What do I do next?
Question Looking for HP tires for reasonable price
After searching, I couldn't find any fourms related to my question so here it is.
I am looking for High performace type tires that are either all season or summer only as it really doesn't rain out here in Cali. I have been suggested a few tires and the names that seem to come up most are the Toyo Proxies (which type, I think there are different versions?) and the Faulken 912's.
Which tire do you perfer, or do you have a better suggestion. I am going to be putting them on my steelies as I can't afford to be spending money on rims too.
(Tire size: 215/50R16)
I am looking to spend between $70-110.00
All your suggestions are much appriciated. Thanks guys.
2005 Nissan Altima 2.5S
Add on's: Fog Lights | PIAA Parking Lights | Audiovox FM Transmitter | Garmin 650 | AEM CAI w/ Driflow and Bypass Valve | Eibach Pro Kit Springs | Yoko V4s Tires
Soon:
KYB GR2 Shocks/struts
Now looking for new tires>, rims (se-r?), tint, (stock 3.5) spoiler, and Job.
Dyno Jet Run (Bone Stock):
Max Horsepower: 118.2WHP @ 3500 RPM
Max Torque: 201.2FT Lbs @ 3000 RPM YEAH!
Old 05-16-2008, 10:37 PM
madsen203's Avatar
What do I do next?
Also, if you know of a cheap place to get them online/retail stores, post that info too please! Thanks!
Mike
Soon:
Old 05-17-2008, 07:08 PM
3.5 Burn0ut's Avatar
3.5 Burn0ut 3.5 Burn0ut is offline
toyo proxies t1r
Old 05-18-2008, 05:50 AM
5SpeedL31's Avatar
5SpeedL31 5SpeedL31 is offline
QR25DE=Ticking Timebomb
Kuhmos' seem to get a lot of praise, especially for the price. Tire Rack has the best prices online, but Americas Tire (several in the Bay Area) will match prices from Tire Rack. Their service is great too.
Old 05-21-2008, 05:13 AM
jimnolimit's Avatar
jimnolimit jimnolimit is offline
2006 3.5 SE AUTO
your looking to go with a lower profile , right ? you can also go a little wider with 225's check the prices with 225/50/16 they might even be cheaper than the 215's .
for prices :
Home - Discount Tire Direct
Tire Rack - Your performance experts for tires and wheels
NWP block-off plate , slotted rotors , hawk HPS pads , ss-lines , hi-temp fluid , progress rear swaybar , falken 512's ZR rated .
14.27 @ 97.29 60' 2.100
Old 05-21-2008, 05:16 AM
madsen203's Avatar
What do I do next?
Originally Posted by jimnolimit View Post
your stock size is 215/60/16 you can go a little wider with 225's check the prices with 225/50,55,60/16 they might even be cheaper .
for prices :
Is this true? WOuld it look off though considering it would be a bit extra wider? I will have to research this... Hmm.. sounds like a good idea. Makes a bigger footprint too.. who knows.
Soon:
Old 05-21-2008, 06:19 AM
jimnolimit's Avatar
2006 3.5 SE AUTO
225 is good
look up tire sizes and prices between 225/50,55,60/16
Old 05-21-2008, 05:26 PM
madsen203's Avatar
What do I do next?
225 is good
Awesome.. Looks like I save around 20/tire going with 225/50R16. I was reading on another forum that if you put a 225 with 50 it is near equilivant to 215 with 60.. I don't want too much of a "lower profile" but I do want a good tire.
Going with the toyo proxes t1r's 215/55-16. Woot. Thanks for your imput guys. YOu rock.
Soon:
Last edited by madsen203 : 05-21-2008 at 06:58 PM. Reason: Can't fit a 225 on my steelies
Old 05-21-2008, 06:14 PM
Pimped-up's Avatar
Pimped-up Pimped-up is offline
Sorry for cutting you off
I would go with the Kumho. 18x8=> 235 (is best fit)
Old 05-21-2008, 06:59 PM
madsen203's Avatar
What do I do next?
I haven't read anything of quality about Kumho... they mostly get bad reviews about the things that matter most to me.... keep in mind I am putting these on my steelies 16*6
Soon:
Old 05-22-2008, 04:38 AM
jimnolimit's Avatar
2006 3.5 SE AUTO
the 225/50/16 is wider and cheaper why are you going with a 215/55/16 ?
Old 05-22-2008, 06:40 AM
phreekee25's Avatar
phreekee25 phreekee25 is online now
slowly losing my sanity..
don't forget that going with a lower profile tire on the same sized wheel will increase your wheel gap and impact your speedo.
for example: overall diameter of 225/50/16 is 1.3" smaller than 215/60/16. when your speedo reads 65mph you will only be driving 61.8mph. (if the alti speedos were actually accurate. lol)
Tire Calculator
Old 05-22-2008, 07:06 AM
jimnolimit's Avatar
2006 3.5 SE AUTO
225/55/16 would be a better size to keep your speed almost correct. speedo will only be off 1 mph at 65 from stock tires
Old 06-02-2008, 05:42 PM
Pimped-up's Avatar
Man, you are definetely missing out about the KUMHO's quality. I am on my second set right now and the way i drive man!? i need to have good tires, and Kumhos are the ones that does the job very well. If not Kumhos? I would go with Yokohamas, but they are a bit more pricey so i reather stick with Kumhos, because i doubt that you will notice a difference between them...
Old 06-02-2008, 09:14 PM
firemoth firemoth is offline
Bro...
if you count the stock tire size as either 205/65/16 or 215/60/16, the closest 225 tire to stock will be 225/60/16. I had those on my 16" wheels.
A 215/55-16 is too low of a profile to keep your speedometer accurate. I'm afraid the widest tire you can get away with on a 16x6.5" wheel is 225...therefore a 225/60/16 will be closest to stock overall diameter, and you can probably get away with a 225/55/16 if you really want to. I wouldn't go to 215/55/16's though; that's too far from stock.
2002 Altima 2.5S
17" ROH Drift-R wheels
235/50ZR17 Federal Formoza FD2 tires
MTX 250 Watt Amp + 12" Rockford Sub
otherwise bone stock - for now!
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
