Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Nissan Tires, Wheels, Brakes & Suspension
Old 07-02-2009, 06:58 AM
Question about brakes
In the Nissan altima 2005 service manual, there are two sections for front brakes, labeled:
CLZ25VD
and
CLZ25VE
My car's an Altima 2005 2.5 S (extra). Which section for the front brakes do I follow?
Thanks!
Old 07-02-2009, 10:12 AM
jimnolimit's Avatar
2006 3.5 SE AUTO
is there a reason you started 3 thread about your brakes ?
do you realize you can ask/post several questions in one thread ?
p.s. i answered this question in one of your other posts .
Old 07-02-2009, 02:16 PM
My bad, i'll remember for next time. I can't seem to find your post about the brakes being either CLZ25VE or CLZ25VD. Could you link me?
Thanks!
Old 07-02-2009, 10:11 PM
jimnolimit's Avatar
2006 3.5 SE AUTO
Thanks!
this is your OEM brake pads :
PAD KIT-DISC BRAKE - Altima (L31) 2002-2004 2.5L & 3.5L, 2005-2006 2.5L :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Old 07-04-2009, 10:38 PM
Hey, so i got my wheels off and checked my brakes, turns out the pads are pretty meaty so i'll leave them unchanged for now. However, the tape on the pads (outer surface) were kind of melted and sticking on the pad (worn out) when i removed the caliper, and when I put the caliper back i just took them off. Is this ok? Should I put them back on? It was hard for me to put the caliper back on because of the tape, which was why i removed it. Should i compress the piston back in a bit to make it easier to put the caliper back on with the tape on the pads? Will the piston come back when I pump my brakes? Thanks!
Old 07-05-2009, 11:01 PM
jimnolimit's Avatar
2006 3.5 SE AUTO
does the pads have the metal shims ?
you should compress the piston just a little to make putting the pads back easier , after your all done pump the brakes a few times till you get a firm pedal .
