205 65 R16 tires - Nissan Forums : Nissan Forum
post #1 of 10 Old 11-09-2010, 04:39 PM Thread Starter
205 65 R16 tires
Made a bunch of phone calls today and located a set of local Bf Goodwrich winter slalom 205 65 R16 tires. They are leftover 2009 tires and are studdable unlike the new BFG slalom's. They are charging me 115$ a tire and 16$ a piece to studd them. 612$ taxes in all 4 installed.
I found a calculator somewhere online that basically said the 205 65 r16 tire is 0.38" larger in diameter then the stock 215 60 r16 tires. I know there will be a slight difference in the speedometer but I don't care, just wondering if there is enough clearance for a taller tire.
Tall and narrow is great for snow and ice, interested to know what the limits are for the 4th gen Altima's.
thanks in advance for any info on running this size or larger winter tires.
curtis
japedo is offline
post #2 of 10 Old 11-09-2010, 05:25 PM
Vital's Avatar
Quoted: 7 Post(s)
iTrader: 11 reviews
0.38'' differance is 0 to me. U'll be just fine.
As far as "limits on 4th gen" - there's people running 20''s (even 22's) with no issues. Obviously that is NOT a good idea for snow/winter tires but it tells you you have all the clearance space u'll ever need with your 205/65/16
I was on 245/45/18 last 2 winters with no issues at all even when it snowed. Not saying it was the best size for winter but it did just fine.
Vital is offline
post #3 of 10 Old 11-09-2010, 05:35 PM Thread Starter
thanks vital for the responce, im not to concerned about the .38 either. Although i know people run differnt sized rims, i want 18s for next summer myself, im wondering about maximum tire outer diameter, which isn't really related to rim size.
thanks again, the peopple are holding the tires for me, but if I could get some taller tires under it i would, im not overly impressed with how low the exhaust hangs down in the back of my 07 2.5.
curtis
japedo is offline
post #4 of 10 Old 11-09-2010, 07:50 PM
Vital's Avatar
Quoted: 7 Post(s)
iTrader: 11 reviews
While rim size doesn't tell u what tire size is on it you can be sure that the smallest tires on 22' will be bigger then just about any tire on 16''
Check out "4th gen wheel and tire thread" to see who has what size tires, lots of xx/zz/Ryy there
Vital is offline
post #5 of 10 Old 11-09-2010, 08:02 PM Thread Starter
cool thank you, I am going to do some more research. I'll post back with what I find.
japedo is offline
post #6 of 10 Old 11-09-2010, 10:18 PM
Common sense advocate
monster289's Avatar
Quoted: 31 Post(s)
Moving this to the tire forum.....
Please try to post in the correct forum next time.
monster289 is offline
post #7 of 10 Old 11-09-2010, 10:23 PM Thread Starter
sure thing, sorry for the trouble.
japedo is offline
post #8 of 10 Old 11-09-2010, 11:32 PM
rwm
What's interesting is the radius - the measurement from the center of the hub to the outer edge of the tire. In your case it's 0.38/2. Not much to worry about. I have 205/60 16 snows for my 2.5S. A bit narrower and about a quarter inch smaller radius. Fine for snow.
rwm is offline
post #9 of 10 Old 11-10-2010, 02:05 AM Thread Starter
thanks for the input, I know what you are saying about the radius, good point.
Does yuor car drag thee rear exhaust and such in deep snow? or does it do ok? thanks.
Curtis
japedo is offline
post #10 of 10 Old 11-10-2010, 02:05 PM
rwm
Curtis
I haven't used them in deep snow yet. But with the car being only a quarter inch lower, I don't think it will make much difference. Most of today's sedans with low ground clearance are going to be bad in deep snow anyway. In deep snow I either stay home or take the pickup ;-)
rwm is offline
