Tire rubbing/grinding noise on turns? - Nissan Forums : Nissan Forum
post #1 of 15 Old 01-25-2011, 04:01 PM Thread Starter
Hi everyone. I've had my 2008 Altima SL since September of 2010 and have been having an issue with it. The car was bought from a reputable auto mall here that inspected the car and everything before I bought it.
Anyway, my issue a noise I'm hearing on turns. It usually happens when doing a sharp turn or a slow turn and the pavement is not leveled, as in going up a hill of some sort.
I am hearing a grinding noise that sounds like the tire is hitting the wheel-well. It doesn't sound like anything mechanical coming from the engine, but strictly from the tire area. Is this normal?
I brought the car back to the dealership and attempted to recreate the noise, but, of course, it did not happen when the mechanic was in the car with me.
Any help would be appreciated!
Jasko is offline
post #2 of 15 Old 01-25-2011, 05:45 PM
jdublup's Avatar
Quoted: 11 Post(s)
Yep, all cars with tires rub the inside of the fender well. It's perfectly normal.
Come on man. No that is not normal.
Do you have stock everything??? Are the wheels/tires on the car OEM? Do they match the recommended size for the car? Does the car look lower than other SL's you see?
If you answer you have 22's on the car, I'm smacking you all the way from VA.
If every thing is stock, check and see if all of the clips are installed that secure the plastic inside the finderwell. If it is hanging down some it may cause an obstruction.
Turn you wheel all the way to the direction you experience the rub. Leave it turned and see what it looks like on that side of the car.
2010 G37x 7AT--Black Obsidian on G37 Coupe Sport 19s
Previous:
07 Altima 3.5SE CVT--Black w/ Charcoal Leather--35% Tint, Custom Fiberglass Enclosure
92 Sentra 2dr--Black w/ Gray Int--238k miles
DMV Area Roll Call
Come rep DC, MD, and VA!!!
jdublup is offline
post #3 of 15 Old 01-25-2011, 05:47 PM
hazmat's Avatar
Definitely NOT normal.
Any signs of rubbing in the wheel well or on the tires? That would be the first thing to look for. Preferably immediately after hearing the noise.
2008 2.5SL
Sonoma Sunset
2007 FX35
Autumn Copper
hazmat is offline
post #4 of 15 Old 01-25-2011, 05:58 PM
xeene's Avatar
Quoted: 6 Post(s)
have you looked inside the wheel wells for rubbing marks?
nissan factory shop manuals
xeene is offline
post #5 of 15 Old 01-25-2011, 06:00 PM
jdublup's Avatar
Quoted: 11 Post(s)
What the hell? This is first time I notice you two had the same two cars.
Previous:
DMV Area Roll Call
jdublup is offline
post #6 of 15 Old 01-25-2011, 06:12 PM Thread Starter
Car is stock. Sorry I forgot to mention that. I know it's not normal, but I've taken it to the dealership twice now, mainly because I am paying for the bumper to bumper extended warranty. The first time I brought my car in, I left it there. I came back about 8 hours later and they said they could not duplicate the sound. Week or two later, I brought it back for the same issue but this time I went in on a week day to have a tech ride with me. I had the guy ride with me and I swear, I was doing doughnuts / sharp turns, everything and it didn't make the noise. Not enough for him to hear it. It slightly made it, but every time I was like "that noise!" he's like, "what noise?" SO frustrating.
It happens whenever I turn left or right, same on both sides. I feel / hear the rubbing. I checked under my wheel wells when I first started hearing it, but didn't notice any wear-and-tear.
I guess I'll have to go back and have the tech ride with me again. It's very frustrating though trying to duplicate the sound. but I know it's there.
Jasko is offline
post #7 of 15 Old 01-25-2011, 08:58 PM
xeene's Avatar
Quoted: 6 Post(s)
doesn't it happen in cold temperatures only or in when it's 100 degrees outside also?
xeene is offline
post #8 of 15 Old 01-25-2011, 09:04 PM Thread Starter
Happens in both. I live in south Florida so I've had the heat and cold fronts. Still.
Jasko is offline
post #9 of 15 Old 01-25-2011, 09:17 PM
Valley Forge
Cool Rubbing/grinding ??
Thanks for this thread. Mine is 07 2.5s with 80k. Kumho tires..stock size.
I've been noticing this sound or feeling only when I take right turn. This is not pavement related. I've tested numerous pavements. I never checked for a mark on the wheel wale. Not sure what the hec it is...However, sometimes it feels like it does it even with a slight turn. Full turn would have made sense.
U guys suspecting CV shaft/joint by any chance ?
KnoX is offline
post #10 of 15 Old 01-26-2011, 02:18 AM
KnoX, I think you have nailed it with the CV joint. Any popping noise while turning is more than likely a CV joint being starved of lubrication. Take off your tire and inspect the CV boot for any rips or tares. If you find one, spend the extra cash and get yourself a genuine Nissan replacement, if you get one at autozone or the like you will be replacing the CV joint in two or three years. I recently had this issue with my car and thought it was the CV joint, but in fact it was a piece of ice that was stuck where I could not see with the tire on. With you being down in Florida I highly doubt that you have an ice chunk stuck haha.
2007 Altima 2.5S-74,000
2006 Sentra 1.8 "Special Edition"- 52,000
BuschKJ24 is offline
post #11 of 15 Old 01-26-2011, 03:20 AM
Same experience with my 08. Spitting image.
I went one time with the tech and was doing donuts and couldn't repeat it.. I was pissed. Makes a grinding type sound when making sharp right turns on uneven surfaces as well. Went back another time when it wasn't raining and I was able to duplicate it much easier. They diagnosed it for free and I think they said the strut was bent... but not 100% sure on that, I will look at the papers which are in my car to make sure thats what they said. I know for a fact they didn't say CV joint because thats what I was suggesting to them and they said it wasn't...
Radiant Silver 2008 2.5S Sedan
OEM Volume Controls
VLEDs LED swap
25% Tint
OEM Autodimming Rearview Mirror
OEM Style Spoiler w/ OEM CHMSL Cover
OEM iPod Interface
Remote Start
DDM Tuning 5000k HIDs
White & Amber LED Strips in F&B Footwells
Overhead & Cubby Hole Ambient Light
OEM Aluminum Kick Plates
OEM Cargo Net
OEM Fogs w/ OEM switch
Cupholder LEDs
Reverse LEDs
SL Window Finishers
Illuminated Grill
Electromagnetic (no holes) Backup Sensor
3.5SE Mirrors w/ Heat and Blinkers
OEM 17" Altima 3.5SE Rims
Advent Bluetooth (BTHFMOD) w/ Nissan Switch
derekg1023 is offline
post #12 of 15 Old 01-26-2011, 05:51 PM
Valley Forge
Cool
BuschKJ24 thanks for your comments and derekg1023 you also mentioned something interesting about strut.
Beside this grinding noise I have always felt something wably from the front driver side tire area. I have rotated and balanced but that never seemed to stop. I always what that could be. Never had to allign it. This wably feeling gets irritating sometimes. I had lots of discussions about this. Some said tires - I think so too, but why one side? I have all new tires Kumho KR21. Great for money.
Thanks. nice discussion.
KnoX is offline
post #13 of 15 Old 01-27-2011, 01:20 AM
um...for a wabel I would think something along the lines of a wheel bearing that is on its way out but the wabel would be pretty bad. Otherwise could a ball joint cause this or a tie rod end? I could be way off though haha.
post #14 of 15 Old 01-27-2011, 02:33 AM
Common sense advocate
monster289's Avatar
Quoted: 31 Post(s)
Moving this to the tire forum.
monster289 is offline
post #15 of 15 Old 01-28-2011, 04:26 PM Thread Starter
I don't have a wable or anything like that. I checked the wheel-wells again the other day and I couldn't notice any wear and tear on anything down there. I bought this car used and it's an 08, so I figure this can't be something new that's just been happening. The tires on the car are brand new from the dealership for when I bought it, maybe they put the wrong tire size on? lol
I dunno. The noise isn't bothering me that much and it's frustrating and hard for me to get to a Nissan dealership from where I live. I guess I'll deal with it for now. I just wanted to make sure it wasn't something that's going to damage my front end of wear my tires down the wrong way. I'll try to make it up to my dealership sometime soon.
Jasko is offline
