Rust inside wheel - what do I do? - Nissan Forums : Nissan Forum
post #1 of 8 Old 03-07-2011, 05:25 AM Thread Starter
Hi All,
I just bought a 2004 Nissan Altima 2.5 S and there seems to be some rust inside the wheel. It doesnt look pretty. I want to eventually paint my brake calipers but I need to get rid of this rust first.
Is it something I can fix easily/cheaply? I dont really have any experience with cars but I can follow instruction and I learn quickly.
Thanks in advance.
1992 Nissan Bluebird ARX-G
1987 Toyota Corolla XL
That-_-Guy__ is offline
post #2 of 8 Old 03-07-2011, 05:35 AM
Biz
VQ'D Sleeper
Biz's Avatar
Quoted: 1 Post(s)
The pictures aren't clear but I assume you are talking about rust on the rotors? That is a common problem. Either take them off, remove the rust and paint with high temp paint on the areas not hit by the pads or replace them with rotors that have a zinc coating. I bought some Raybestos rear rotors that are powder coated black. They are powdercoated on most of the non-wear areas so they keep a better look.
Rust on the calipers are handled the same way: remove caliper, remove the rust with a wire brush, paint with high temp paint.
2003 3.5 4AT
Racingline | Nismo | Optima | Weapon-R | Stillen | Raybestos | BT | 4DZC | VLEDS
Biz is offline
post #3 of 8 Old 03-07-2011, 05:44 AM
Biz summed it up pretty well for you. That's just rust on the hats of the rotors. It's not detrimental to anything, it's just ugly. Mine look the same, and I plan to either get zinc coated rotors or buy the PC'd ones to avoid it in the future.
2006 Nissan Altima SE-R | 3.5L 214ci VQ35DE DOHC 60 V6 | 6MT
Racingline HFPCs and y-pipe, NWP VIAS delete, Goodridge stainless brake lines, EBC Green Stuff pads, removed airbox snorkel, deburgered.
1997 Pontiac Grand Prix GTP | Supercharged 3.8L 231ci 90 V6 | 4T65E HD
Intake, DHP 1.5, SD hood.
digitaloutsider is offline
post #4 of 8 Old 03-07-2011, 05:51 AM Thread Starter
Thanks for the quick reply guys. OK so they are rotors, good to know.
Im glad its not detrimental to anything. But yea still very ugly. I think I'll still try and clean up the ones I have and if that goes bad I'll spend some money on powder coated ones.
Cheers.
post #5 of 8 Old 03-08-2011, 03:10 AM
Biz
VQ'D Sleeper
Biz's Avatar
Quoted: 1 Post(s)
The rear rotors listed in my signature were 120.00 at O'Reilly auto parts. They don't have the drilled and slotted look but are just right for a sleeper car. You could also buy some new zinc plated rotors on ebay for not too much.
Another note: it looks like your brake pad wear indicator may be rubbing on your rotors (see your lower picture). Check your brake pads to see if they are needing replacement too.
2003 3.5 4AT
Biz is offline
post #6 of 8 Old 03-08-2011, 05:27 AM Thread Starter
Havent heard of O'Reillys. They might not have it here in Canada. I think my rotors/brakes are good (atleast thats what the service record showed that the dealer gave me when I bought it a few weeks ago).
I took the wheel off to get a better look at it today.
So then I went to Canadian Tire and bought a can of deruster stuff and a wire brush to clean it all off and I also bought some high temp paint to make it look good, hopefully.
I'll post an after pic once im done tomorrow night.
post #7 of 8 Old 03-09-2011, 03:19 AM
Might have a problem
edk20's Avatar
what kind of high temp paint did you purchase? thats pretty much how much mine look.
edk20 is offline
post #8 of 8 Old 03-09-2011, 04:18 AM
dvo2's Avatar
There's a specific spray paint at auto stores that stops rust and comes in black and stuff. You just spray it on and it stops the rust. No sanding. I used it on my subframe that was rusting from being low. Lol
Originally Posted by TUKO316 View Post
Cheerios are for pussies.
I eat wheaties. Hence the reason I'm full of win.
95 Honda Accord lx Sold
05 Nissan Altima 2.5s Auto
03 Acura RSX base 5spd
dvo2 is offline
