How long will stock shocks last with lowering springs - Nissan Forums : Nissan Forum
post #1 of 20 Old 06-03-2011, 10:17 PM Thread Starter
I do quite a bit a miles and i've heard that when people lower their car they usually in the long run end up going to coilovers because the stock shocks are shot. Around how many miles would this happen (mostly hwy) if you put on lowering springs (car fairly new).
My question is do i just do springs and deal with the shock issue when it comes...or save up forever to get coilovers. Don't say "go coilovers" cause duh...everybody wants them.
Woody17 is offline
post #2 of 20 Old 06-04-2011, 12:40 AM
saywat?'s Avatar
Quoted: 22 Post(s)
put tein springs in the altima brand new back in 06. still going strong. i believe theres about 50k+ miles on it
"Sorry Gramps, My Altima's Nicer Than Yours"
"I would like to apologize in advance for being brutally honest!"
MODS:
- Cargo Net retrofitted in the trunk
- 10w HID Converted Dome Lamp
- 8w HID Converted Door Lamps
- Removed OEM FogLight Covers
- Relocated "Special Edition" badge
- Custom Floor Mats with visible "Special Edition" Logo
saywat? is offline
post #3 of 20 Old 06-04-2011, 01:46 AM
Winner March 2010 NOTM
hattrick3518's Avatar
Quoted: 3 Post(s)
Sounds like you're in the situation I was a couple of years ago. I purchased and installed some Tein S.Techs, on stock struts. I rode with the springs for 1.5 years (40k+ miles) , but the struts failed at about the 8-10 month mark, so I had about half the time on okay struts, and the rest on blown struts. On blown struts the ride was miserable, I could hear them clanking around, and there was no shock absorption at all, it was just like riding on some springs that happened to be mounted to solid steel struts.
When the time finally came to replace the struts, it came time to make a decision. I did not really want to reinstall struts (compressing the springs is a bitch), so I looked around for a set of lightly used coilovers. Turned out I could get some coilovers for ~$500 shipped, while I could get some struts (+install) for about $350. I then saw what I could sell my springs for ($125-$150), so when it came down to it, it was easy for me to jump to coilovers, as they were essentially equal to the cost of new struts (Coilovers: $500-$150=$350. Struts: $350 [parts+install]).
For the time being, it cant hurt to just go with the springs to start out with, the struts will fail sooner or later, highway driving or not (I commuted 50 miles a day ALL highway, and mine still failed). Coilovers maybe better in the long run, but only if you actually care to have adjustable ride height and dampening. If not then springs are just fine.
Hope that helped a bit, feel free to PM me or reply here if you have any more questions.
hattrick3518 is offline
post #4 of 20 Old 06-04-2011, 01:59 AM
Altimer
Mike James's Avatar
Quoted: 68 Post(s)
If you were to install springs, such as the s-tech's, swap out the struts and shocks for some KYB's at the same time and you're all set. Your stock struts and shocks will not last long with a lowered setup. Mine lasted about a year and was unbearable at the end.
Altima traded for Odyssey
Current - 08 HIGHLANDER
Mike James is offline
post #5 of 20 Old 06-04-2011, 06:21 AM Thread Starter
so...sounds like go just go with the coilovers. sorry for my lack of knowledge here...my plan was to do eibach springs OR lighty used coilovers. sounds like the consensus is to just go straight to coilovers...
thanks for your thoughts
Woody17 is offline
post #6 of 20 Old 06-04-2011, 07:36 AM
Quoted: 3 Post(s)
Coilovers if you want full adjustability. They don't offer ride comfort, but do offer adjustability and track performance.
post #7 of 20 Old 06-04-2011, 03:07 PM Thread Starter
lol i drive a hybrid...i'm looking to just get a little more performance and mainly to get rid of the horrible wheel well gap. as far as performance goes..i'm not really going for much.
Woody17 is offline
post #8 of 20 Old 06-04-2011, 03:17 PM
Quoted: 3 Post(s)
Then you would essentially be wasting the additional $500 that coilovers are going to cost you. In your case, just for looks, go with a new shock/spring combo > coilovers.
post #9 of 20 Old 06-04-2011, 03:42 PM
Altimer
Mike James's Avatar
Quoted: 68 Post(s)
I've only read once where someone has lowered their hybrid. They purchased Eibach springs then had to install an isolator in the top mount to raise the back end up. Back end sits down way too far because of the heavy batteries.
post #10 of 20 Old 06-05-2011, 08:03 PM Thread Starter
i was thinking this would be the cheapest way...i can get a lightly used set of d2's for $650. not worth it? what do you mean replace the shock/spring combo...eibach springs with what shocks? obviously the performance upgrade by lowering is wanted...but this is a daily driver for me so i need something that will last.
a couple of guys have done it...the two ways i've seen are:
- rtking: "Energy Suspension" polyurethane pads: Lowering the Nissan Altima Hybrid : Altima Hybrid
- victore1123 (i believe)- can't find the post but he put like a spring stop or something between two parts of the spring in turn lifting the back.
Woody17 is offline
post #11 of 20 Old 06-05-2011, 08:25 PM Thread Starter
Woody17 is offline
post #12 of 20 Old 06-05-2011, 09:03 PM Thread Starter
so, coilovers do not offer as comfy a ride as a set of say, eibachs and new shocks/struts? what am i looking at cost wise for the new shocks and struts?
Woody17 is offline
post #13 of 20 Old 06-05-2011, 09:12 PM
Quoted: 3 Post(s)
No, not usually, not those D2's anyways. Look at KYB GR2 shocks and struts. Matched with springs, it shouldn't run you more than $450.
post #14 of 20 Old 06-06-2011, 02:47 AM Thread Starter
thanks for the info!
does the kyb shock/strut sit lower? why will this work better with the eibach lowering spring vs. the stock one? is it adjustable or something? researching now...
Woody17 is offline
post #15 of 20 Old 06-06-2011, 03:06 AM Thread Starter
the kyb catalog explicitly says not for the hybrid:
NISSAN Altima
2010 Sedan (Exc. Hybrid) Right Hand 339146
Left Hand 339147
Base & S Models (Sedan Only) 349075
Any alternatives?
Woody17 is offline
