Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 04-04-2005, 04:21 AM
Help: 1997 Pathfinder "Service Engine Soon" What could it mean?
My father's 1997 Pathfinder had the "service engine soon" red light pop up a couple days ago. He saw that and hasn't started the car since because he's afraid he might damange the engine further.
It's got ~138K miles. He does somewhat regular oil changes. He hasn't changed the timing belt yet (typically done ~120K miles). Would that be a reason for that light? In general, whattypes of things cause Nissans to have that service indicator light up? Thanks
Old 04-04-2005, 04:22 AM
Prey521's Avatar
Reppin Lower East Side!!!
Just take it to any Autozone and have them check the codes for you, they do it for free, could be anything.
Flickr: Prey521's Photostream
Old 04-04-2005, 04:31 AM
Al Bundy's Friend Griff's Avatar
Look in the owners manual.
Old 04-04-2005, 04:42 AM
Always something better
4x4parts.com do a search their but you can drive it, the light means lots of things not just the engine
Old 04-04-2005, 05:29 AM
He doens't have the owner's manual. Anyway, how do we check the codes? I know how to do it for some cars, but not this one. Thanks.
Old 04-04-2005, 12:55 PM
Morpheus's Avatar
Lord of the Thighs
This is just a wild guess and all, but I'm thinking it means he should get his engine serviced soon.
I am Jack's raging bile duct.
Old 04-04-2005, 01:37 PM
Ricam78's Avatar
This is the easiest thing to do. They tell you the code and what it means. Usually its just a sensor that has failed and needs to be replaced.
Rich
QR25DE : CHECK YOUR DAMN BUTTERFLY SCREWS
http://www.nissanclub.com/forums/sho...d.php?t=189462
MY REGISTRY
Old 04-04-2005, 02:21 PM
Xtrema's Avatar
The easiest thing to do is to check the gas cap. Make sure it's locked in properly. A loss in gas tank pressure will prompt similar symptom.
The next is air flow, may be a MAF failure. But that you'll need to read the code to make sure.
There is no sensor the check timing belt. Typical belt has about 70-80K mile life although manual recommend change @ every 60K. @ 138K, I think a timing belt is definately due. If that sucka goes, you'll need a new engine.
Old 04-04-2005, 03:13 PM
NVS aLtiMa's Avatar
Sarcastic Member
Dont worry yourself, my friends service engine soon light has been on for 3 yrs with his car and hasn't broken down yet
Shot at 2007-07-13
03 SE 5sp*traded
05 SER 6sp
93 Camry LE-277k miles and still going as of 09/09
http://www.cardomain.com/ride/285101/1
Old 04-04-2005, 05:00 PM
BLACK SE's Avatar
I keep em comin back.....
run codes with the OBDII scanner at Autozone, then source your problem from there....
