Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 08-25-2007, 05:05 PM
fishbone's Avatar
LOL AWD
Xterra: Regular or Premium
My sister is considering an Xterra and I told her to pretty much look at it as requiring premium for best performance and mileage, as with all VQ engines.
Isn't it true that on regular the VQ40DE retards the timing and doesn't run as good, also affecting mileage? Is regular safe to use on a regular basis?
My snail eats rice
Stage 2 Legacy tuned by Jesus
synthetic oil drained every 500 miles cause I'm rich | uranium-core sparkplugs | McRae sticker 10hp edition | titanium piston springs | Motul syn blinker fluid | timing advanced 6* Celsius | SE-R tail lights | trunk mount intercooler | oil catchcan with exhaust dumpvalve (see smoke in sigpic) | CLICK to see my turbo
Old 08-27-2007, 08:33 AM
canadiantj's Avatar
My wife's hotter!!
Just finished reading the 06 Xterra manual (don't know about the 07/08 one) as I'm just about to purchase one. It states that the recommended fuel is 87 octane. Your sister would just be wasting money on the premium fuel.
'07 Ebony 2.5 s with cvt and convenience/ 35%f 20%r tint /18" 350z touring rims/magnaflow 14829's/4300k HID, Fujita SRI
'06 Xterra SE Night Armor full load: the wife's
Old 08-27-2007, 02:53 PM
fishbone's Avatar
LOL AWD
Are you sure, because when we read the manual for the 07 it said premium recommended for best performance. A Nissan master tech also said this
While 87 can run in the 4.0 liter engine I bet the use of premium will pay for it self in better fuel milage and longer engine life. I also reccomend energy saving motor oils. Castrol Syntec or Mobil One extended life oils. Some people get the idea I am saving 25 cents a gallon and forget 3 to 4 more miles a gallon that having the slower burning fuel allows the engine to run to its full pontential.
I'm going to look at the manual again.
Old 08-28-2007, 02:44 AM
Nismom's Avatar
Know your role...
87 is also recommended for the Titan, and I ONLY use Chevron.
Originally Posted by MADMIKE
did you know nismom makes more advances on young boys then chris and michael jackson combined
Originally Posted by Magoo View Post
You're so sleazy. I can't even make fun of you.
Old 09-03-2007, 11:26 PM
premium
Old 09-04-2007, 07:32 AM
canadiantj's Avatar
My wife's hotter!!
You're wasting your money. From the owners manual:
The following are approximate capacities. The actual refill capacities may be a little different. When refilling, follow
described in the “Maintenance and do-it-yourself” section to determine the proper refill capacity.
Capacity (Approximate) Recommended Fluids and Lubricants
US measure Imp measure Liter
Fuel 21 1/8gal 17-5/8 gal 80 Unleaded gasoline with an octane rating of at least 87 AKI (RON 91)*1
Engine oil *8
Drain and Refill
With oil filter change 5-3/8 qt 4-1/2 qt 5.1 • API Certification Mark *2 *3
• API grade SL, Energy Conserving *2 *3
• ILSAC grade GF-III*2 *3 Without oil filter change 5-1/8 qt 4-1/4 qt 4.8
Cooling system
With reservoir
2-3/4 gal 2-1/4 gal 10.2 50% Genuine NISSAN Long Life Antifreeze/Coolant or equivalent
50% Demineralized or distilled water
Manual transmission gear oil 2WD 4-1/4 qt 3-1/2 qt 3.98 Genuine NISSAN Manual Transmission Fluid (MTF) HQ Multi 75W-85 or API GL-4, Viscosity
4WD 4-3/8 qt 3-5/8 qt 4.18
Automatic transmission fluid Refill to the proper level according to the
instructions in the “Maintenance and do-ityourself
” section.
Genuine NISSAN Matic J ATF *4
Power steering fluid (PSF) Genuine NISSAN PSF or equivalent.*5
Brake and clutch fluid Genuine NISSAN Super Heavy Duty Brake Fluid*6 or equivalent DOT 3
Multi-purpose grease — — — NLGI No. 2 (Lithium Soap base)
Air conditioning system refrigerant — — — HFC-134a (R-134a)*7
Air conditioning system oil — — — NISSAN A/C System Oil Type R (DH-PS) or equivalent*7
Transfer fluid — — — Genuine NISSAN Matic D ATF (Continental U.S. and Alaska) or Canada NISSAN Automatic Transmission
Front final drive oil — — — API GL-5 SAE 80W-90 Gear Oil, *9, *10
Rear final drive oil
Except 6 speed MT and 4X4 O/R vehicles — — — API GL-5 Synthetic 75W-90 Gear Oil, *10
6 speed MT and 4X4 O/R vehicles only — — — API GL-5 Synthetic 75W-140 Gear Oil, *10
Windshield washer fluid (shared between front and rear wipers) 1-1/4 gal 1 gal 4.5 Genuine NISSAN Windshield Washer Concentrate Cleaner & Antifreeze fluid or equivalent
*1: For further details, see “Fuel recommendation.”
*2: For further details, see “Engine oil and oil filter recommendations.”
*3: For further details, see “Recommended SAE engine oil viscosity.”
*4: Using automatic transmission fluid other than Genuine NISSAN Matic J ATF will cause deterioration in driveability and automatic transmission durability, and may damage the automatic transmission, which is
NISSAN new vehicle limited warranty.
*5: For Canada, NISSAN Automatic Transmission Fluid (ATF), DEXRON™ III/MERCON™, or equivalent ATF may also be used.
*6: Available in mainland USA through your NISSAN dealer.
*7: For further details, see “Air conditioner specification label.”
*8: For further details, see “Changing engine oil.”
*9: For hot climates, viscosity SAE 90 is suitable for ambient temperatures above 0°C (32°F).
*10: See your NISSAN dealer for service.
CAPACITIES AND RECOMMENDED
FUEL/LUBRICANTS
9-2 Technical and consumer information
Old 09-18-2007, 04:08 PM
SHAWN's Avatar
Import Tech.
Our '06 Pathfinder says Premium for best performance , but I always run regular , well unless I am towing , then I run Premium .... she will be fine with regular ...!
Yea, you will probably get a couple more HP using Premium , but I doubt it will ever be noticed ....
SHAWN
Ger-Brock & Co. Portland OR.
Japanese import performance and repair .
'98 Forester L Driver/Corner carver
'06 Pathfinder SE
'99 Sentra SE-L For Sale
'98 Sentra SE Time Attack Car
'93 Altima SE 5 spd. (SOLD)
13.97 @ 97 MPH ... All Motor !!
My Nissan Site !!
