Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 02-02-2008, 05:19 AM
D21 clutch slave failing 4x's
I have an 89 se v6 4wd extra cab. The clutch slave started going a year ago, and since have replaced it 3 times. In the mean time I have been feeding the monster break fluid. If it didnt start dailey, I might trash it, but it runs soooo good. 246,000 mi. Does anybody have any idea what would cause the slave to leak time after time?
Old 02-24-2008, 06:20 AM
Resident NICO Mod
If the slave cylinder is leaking each time you install a new one I'd question your installer. Either you are not hooking it up correctly or you are damaging it during install. Remove the leaking one, check where it is leaking from then see what you can do to correct the problem. It's not a difficult system to work on.
1995 Nissan D21 Hardbody 4x2 5spd 2.4L.
