Go Back   Nissan Forums: Nissan Altima Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 11-07-2008, 10:01 PM
Altima_Junkie's Avatar
97.5 Altima SE 5-Spd
Similarities between '95 pathfinder and honda passport?
How alike are the '95 nissan pathfinder and honda passport v6 engine-wise? I figure since bodystyle-wise they look almost identical that they might use the same engine platform. I have a friend who is having a ticking sound problem coming from a cylinder on his passport and it's driving him insane as to what it could be. Just from the sound of it, it sounds like a bad valve spring to me, but i could be wrong. Any idea what it could be?
And yes i've already looked at the honda forums but they don't have a passport forum so no luck there. Just trying to help a friend out.
97.5 Altima SE 5-speed|stock alloy wheels|Stock City struts n springs|60mm autoTB|OBX TB Spacer|K&N WAI|200W JVC KD-LH1150 head unit|500W 12'' MA Audio sub/sealed box|400W 2-channel Rockford amp-bridged|Rockford 60Wrms p168c 2-ways in front doors
I'm Happy, I'm Feelin Glad, I Got Sunshine In A Bag. I'm Useless, But Not For Long, My Future Is Coming On..
-----If you have less than 50 posts and you ask a question, chances are it's been covered...SEARCH-----
Old 11-07-2008, 10:21 PM
Asleep's Avatar
gettin bradb riled up!
theyre not.
at least, the passport shares the same platform with the isuzu rodeo.
Originally Posted by Rick View Post
asleep is a stream of off-color and low-cooth jokes in person as well. I've been recycling jokes I heard from him for years. He is known by my friends as "the sick fuck."
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
RIP Elisa Lupe Katayama Dec 22 1953 - Dec 24 2008
www.cardomain.com/id/hotlicia
Old 11-07-2008, 10:54 PM
thanks man. well bodywise that year of all 3 of those look eerily similar to me. which i thought was wierd becuase I know honda and nissan don't share platforms like nissans and infinitis do. I'll check out the isuzu forums(if i can find any) and look around there... from experience though, the ticking noise sounds too loud to be the injectors and too soft to be anything like a bad connecting rod. I used to have an 89 s10 that had a similar noise and it ended up being a bad valve spring(hence that being my first thought on his passport.)
Old 11-07-2008, 10:58 PM
Asleep's Avatar
also, look for exhaust manifold gasket leaks.
Old 11-07-2008, 11:08 PM
how would you test for leaks on that gasket?
Old 11-07-2008, 11:10 PM
Asleep's Avatar
you can sometimes feel exhaust leaks with your hand. you can also hear them with a pipe.
or, look for carbon soot streaks around the ports.
Old 11-07-2008, 11:18 PM
ok. i'll have him try that. I believe he was thinking about putting new gaskets(valve cover, exhaust manifold) anyways so that might just fix the problem if that's it. Although the ticking sounds kinda metallic so i'm not sure if it's being cuased by an engine part or a leaky gasket. Appreciate the help man.
Old 11-15-2008, 03:42 PM
1800bucks's Avatar
Cheap Bastard
Might want to check out Pirate4x4. Like has been said, the Rodeo and the Passport are one and the same. It should have the 3.2L Isuzu in it. Pirate4x4 are some diehard offroaders, but IIRC, there is an Isuzu forum on there.
