Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 11-16-2008, 11:33 PM
Sassan's Avatar
Super Moderator
Problems with my QX4 starting
QX4 = same as the Pathfinder......
I bought a new battery in March 07.
Here we are now, Nov 08, and the car has been having a hard time starting sometimes, and sometimes it fires right up. I was thinking, maybe the starter, maybe the battery. My wife went to use the car a couple of weeks ago and didn't realize it was on and tried to start it, so thats why I am thinking the starter may have been damaged.
Took the battery to Advanced and they checked it, and the battery tested bad, so I got a new one under warranty. That in itself, is a bit concerning because why did the battery go bad after just a 18 months after being installed....hoping it is because of manufacturer defect.
Put in the new battery, and the car would not start for nothing. FINALLY got it started, drove for a few minutes, came home and parked it, then tried starting it 10 times in a row, and each time, no issue.
Starter bad?
I still have a check engine light on, but nobody knows what the code means, not even the Infiniti dealers. I think its an O2 sensor because its related to emissions, and it comes and goes.
Thoughts please.
Old 11-16-2008, 11:55 PM
porschebk85's Avatar
2nd Gen Boy
Are you sure the alternator is working correctly and charging the battery? A lot of people grind the gears in the starter, doing it just once shouldn't have damaged that much.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
2001 Altima GXE - [8K HIDs] [De-badged] [ UR Pulley ] [injen intake] [OEM Spoiler] [OBX TB Spacer] [40% Tint] [ Stillen Rotors & Hawk HPS Pads] [TYC Tails] [ license]
<Car Domain> <♪My Pandora♪> Proud fiancés of an EMT-I/Firefighter
Old 11-17-2008, 01:23 AM
Sassan's Avatar
Super Moderator
I guess the alternator is working....not 100% sure though.
Old 11-17-2008, 01:29 AM
2nd Gen Boy
Well alot of shops including auto zone will check you alternator for free, I might have that done before you spend money on something else. Its always better to cancel out anything else it could possible be. But its up to you.
Old 11-18-2008, 12:40 AM
Sassan's Avatar
Super Moderator
I don't think its the alternator.....
You don't have to tell me about alternators....I am the alternator killer. Ask around.
Old 11-18-2008, 12:45 AM
2nd Gen Boy
Well I figured you being a mod on supernissans and your post count here, but I just submitted it for advice.
Old 11-19-2008, 02:12 AM
Sassan's Avatar
Super Moderator
Er, not the mod, just the Admin.
Old 11-19-2008, 03:00 AM
2nd Gen Boy
Cool
Ah... that is probably why I didn't get the mod position I tried to get. lol
Old 11-23-2008, 05:39 PM
2nd Gen Boy
Did you ever find out what caused the no-start condition problem??
Old 11-23-2008, 08:08 PM
Sassan's Avatar
Super Moderator
Last week, took the battery in, and they gave me a new one.
Last night, same thing again, car wouldn't start. I tried it a few times, and got it fired up.
Today, it will not start AT ALL. My logic is this.....battery, alternator, starter....so I checked the connections on the battery and all the fuses, everything is fine. Everything powers up too, and I know it takes more to start a car, but still, just checked that. Since that didn't work, tried to jump the car....figured if it is the battery, jumping it would get it started at least. That didn't work.
The only thing I have not checked yet is the starter, cuz I can't find it.
Is my thinking correct?
Old 11-23-2008, 08:51 PM
2nd Gen Boy
Yeah... You've canceled everything else out, I guess the starter is worth checking. Does the battery get drained, is that why it keeps on getting replaced?
Whats draining the battery?
Old 11-24-2008, 02:11 AM
Sassan's Avatar
Super Moderator
First battery was the original....not sure why the second drained.
Old 11-25-2008, 03:59 PM
SHAWN's Avatar
Import Tech.
depending on the year , these have a common issue with the starter relay ... some have a large blue relay on the right fender well ... they tend to go bad ... and yea, the starter could be an issue , I have seen them go bad .... or the ignition switch or the Inhibitor switch .... List goes on and on ...
You would have to check the signal into the starter to see if its getting a good 12v signal while cranking ...if it is then its probably a bad starter ..if its not ... then you have to find out why ...
SHAWN
Ger-Brock & Co. Portland OR.
Japanese import performance and repair .
'98 Forester L Driver/Corner carver
'06 Pathfinder SE
'99 Sentra SE-L For Sale
'98 Sentra SE Time Attack Car
'93 Altima SE 5 spd. (SOLD)
13.97 @ 97 MPH ... All Motor !!
My Nissan Site !!
Old 12-11-2008, 03:38 PM
2nd Gen Boy
So any new news on this Sassan?
Old 12-21-2008, 05:06 AM
Sassan's Avatar
Super Moderator
Everything worked fine until today. Won't start again. Gonna try to get it back to the dealer and bitch at them. I am gonna mention the starter relay to them and see what they say....
