Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Trucks & Off Road Forum
Old 06-29-2009, 05:01 PM
Grease seals front axle 2WD
I have replaced front rotors and calipers wheel bearings on my two wheel drive 720 pickup.
It is routine to always replace the front axle grease seals with this job.
However it is not clear which way to install the seal. The sketch in the factory manual is not clear, but seems to show the flat side of the seal toward the bearings.
When I removed the old ones they were installed with the flat side away from the bearings and the side with the round spring inside the grease cavity.
It looks to me like if the flat side is in toward the bearing, the rotating bearing cage could rub against where the rubber is sealed to the steel ring
Does it matter? The old ones did not leak. Can they go either way?
Thanks,
Richard
Old 07-02-2009, 11:12 PM
SHAWN's Avatar
Import Tech.
Flat side away from the bearing .... cavity twards the bearing ...
SHAWN
Ger-Brock & Co. Portland OR.
Japanese import performance and repair .
'98 Forester L Driver/Corner carver
'06 Pathfinder SE
'99 Sentra SE-L For Sale
'98 Sentra SE Time Attack Car
'93 Altima SE 5 spd. (SOLD)
13.97 @ 97 MPH ... All Motor !!
My Nissan Site !!
