Ask and you shall receive.
OLD SCHOOL's SLEEPER.
Under The Hood
FULLY Built Motor
Darton Mid Sleeves Bored .030 over (decked, honed, bored, line honed, bearings)
CP pistons 8.5:1 compression
Carillo Rods
Ferrera 1mm oversized Valves
Titanium Valve springs
Valve locks
Spring locators
5 angle valve job
Tomei 268 cams
Balanced Crank
Revup oil pump
Nismo thermo
HKS metal head gasket
Custom L19 Studs
ARP Rod Bolts
ARP Main Studs
Walbro 255 fuel pump
RC 750cc injectors
Fluidamper Harmonic Crank Dampener
Cooling mod (DA Tank, lines, fittings, etc)
Greddy Twin Turbo Kit (turbos, BOV, piping, etc)
Greddy Intercooler
Greddy PRofec B-specII Boost Controller
SGP Racing oil cooler
SGP Racing fuel return system
Aeromotive FPR
SGP Racing Wastegate reloction kit with open dumps
SGP Racing 3" downpipes
AAM Dual 3" exhaust
Cusco air deverter plate
Nismo Oil cap
Samco Hoses
PWR Radiator
Carbonetics Triple Disc Clutch / Flywheel
Nitrous Express wet kit
Nitrous Express purge solenoid
NOS intercooler spray bar
Zex Bottle heater
Dynotune Nitrous TPS/Window switch
Suspension/Brakes
HKS Hipermax III coilovers
SPL front upper a-arms
Eibach Sway Bars (front and rear)
SPL Rear Camber Arms
APS strut tower brace
Stoptech Stage 2 Brakes
(Axxis Pads, Steel Braided Lines, Slotted Rotors, Race fluid)
Interior
JVC DVD audiophile headunit (3.5" screen - single din)
Farenheit 7" screen in navigation cubby hole
Infinity Reference components 6.5"
Infinity Reference coaxils 5.25"
Diamond Audio (2) 8" subwoofers
Memphis Audio 1000D (1100 x 1 @ 1 ohm...running at 300 x 2 watts @ 4 ohm)
Phoenix Gold ZX475 titanium amp (75 x 4 @ 4 ohms) OLD SCHOOL Phoenix Gold - made in USA.
Defi Boost Gauge with Defi Controller
Aspec Titanium Shift Knob
FCON VPRO Stand alone EMS (with Knock AMP and Wide band)
Uprev Osiris reflash on ECU
Blitz Throttle Control (no more drive-by-wire lag)
Hidden NX bottle in gym back - switches in ashtray
Clifford Alarm with remote start
Exterior
S2000 Antenna
Custom made TT fender emblems
2008 LED tail lights (oem)
Wheels/Tires
Rear setup
Drag -BFG Drag Radials (275/35/18) on Stock 18s
Street - Street tires BFG KDW (255/40/18) on stock 18s
5zigen fn01r-c 18x9.5 Toyo Proxy T1R (285/35/10)
Front setup
BFG KDWs (245/35/18) on stock 18
5zigen fn01r-c 18x8.5 Toyo Proxy T1R (255/35/18)
Sleeved block in the bag...woot!
bagged up heads with tomei cams...
motor on the engine stand...being put together.
progress on the engine stand...
its in!!!
Time to play...
13psi
