I know in the R33 GTS-t you can cut a wire that connects into the ECU (wire 53 from memory – In the 33’s at least) and this will remove the speed limiter and have heard you can do the same for the R32’s as well. This would be a quick, easy and cheap solution to your problem. However I have heard rumours of some having problems with the HICAS after this modification has been done, this is probably not something you want to play up at +200kph speeds. I guess if you’re keen enough you could search around for a R32 wiring diagram and find out which wire needs to be cut.
Alternatively, as you are in the process of modifying your car you should look at some sort of aftermarket ecu. You could go for a Power FC if your car is manual (you will have to get the AP engineered version for an R32) and this would remove the speed limiter. This would be the preferred option in my opinion.
Why the need to go over 200 kmph, keeping it for the track it hope?
