Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN 240SX / SILVIA FORUMS > SR20DET Engine Discussion
Old 11-18-2005, 01:14 AM
Blacktop problems
i just bought a 96 240 that has a blacktop in it. it seems to sputter at about 4000 to 4500 rpms in all gears. but then will catch up to itself and go & boost like normal. what could be the problem? i check all my vac lines and my intercooler pipes for leaks. the car also has a turbo 300 zx fuel pump in it.
Old 11-18-2005, 03:53 AM
Siizzzoooo's Avatar
Nissan God
change spark plugs, run a colder plug if possible, if u can't, some replacement platinum plugs should do it, but u'll have to change these often.
gap .28-.30
should fix your problem
1994 300ZX Twin Turbo w/ bolt ons|07 Altima 2.5SL w/ Tech Package |1978 Datsun Project RB
Old 11-20-2005, 12:10 AM
still not running right
k i just changed the plugs and the fuel filter, but the problem has not been fix. anymore ideas?
Old 11-20-2005, 03:10 AM
Siizzzoooo's Avatar
Nissan God
hows the idle? do you smell gasoline?
Old 11-20-2005, 04:24 PM
it runs the same.
Old 11-20-2005, 05:25 PM
Ace's Avatar
Ace Ace is offline
Rockin the Kasbah
Your timing could be a tad off as well.
What Fuel Pressure are you at???
Could also 'possibly' be a knock sensor.....
97 240 - SR Power - 400whp
365th EN - OIF 3+4
Turbo Altima
Old 11-26-2005, 02:00 PM
sounds like retarded timing maybe. has no low end power, then around 4000 or so it starts to move? check your timing...there is a really long precedure for doing this, so do it right.
Dirty
Old 11-27-2005, 09:59 PM
the problem only starts when the throttle is at 80% and when the motor is cold. i'm also having a hell of a time get the temp up in the motor. it runs at about 80 deg C. thats after it "warms" up. i tried to put ardboard in front of the radiator but it still runs at the same temp. is there a good link to explain how to check my timing
Old 12-08-2005, 02:56 PM
check your sparkplug gap. if they're pre-gapped, decrease it down to around .025-.027
It's likely that the boost is "blowing out" the spark.
"This is now....how can I change tomorrow, if I can't change today!? If I control myself, I control my destiny." -Hatebreed
