Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN 240SX / SILVIA FORUMS > SR20DET Engine Discussion
Old 05-26-2006, 11:04 PM
HELP!! battery charging problem
i'm having trouble troubleshooting what is causing my battery to loose its charge while the engine is running. i'tll be at full 12v and within 5 min of running the engine it'll drop to almost 7v and then stalls out. you would think that its the alternator but i pulled it off and had a load test ran on it and it came out good. the battery was also tested and its good. i've tested the charge wire and also the wire that plugs into the alternator and they both are pushin 12v. also the check battery light stays on while the car is running. i've never had this problem before and it just started happening recently. but its so bad now that i can't even drive the car. anyone have any suggestions
Old 06-03-2006, 09:35 PM
Ace's Avatar
Ace Ace is offline
Rockin the Kasbah
Try a different alternator. Maybe it tests fine, but under load it's different.
97 240 - SR Power - 400whp
365th EN - OIF 3+4
Turbo Altima
Old 06-04-2006, 10:22 PM
yeah i even tried a new alternator and still same result
