Prewired for fog? How to check. - Page 16 - Nissan Forums : Nissan Forum
  #226 (permalink)
Old 01-03-2013, 05:05 AM
my 2.5 S doesnt come with fogs, but the outline of fog lights are there, is there a site that has a replacement piece WITH the fog-lights attached so i can wire them? or do i have to cutout the fog-light section to make room (its cuz i have unsteady hands and hate doing it, i dont want to mess up)
2012 Altima Coupe 2.5 S
  #227 (permalink)
Old 01-03-2013, 04:59 PM
DLS DLS is offline
Bordering on Insanity
Originally Posted by NissanMan09 View Post
... If you have a fuse in the FOG place you are pre wired...
You have to actually see if there are wires coming from the wiring block, not just look to see if a fuse is in place. There are some iterations with a fuse but no wires.
The fuses are installed in the holders prior to the installation of the box on the assembly line. It's cheaper to put a fuse in every assembly than to keep track if this particular assembly will be used on a wired car versus a non-wired car.
'09 Altima 2.5S CVT 65K
'10 Armada SE 4WD 55K
  #228 (permalink)
Old 01-03-2013, 05:05 PM
DLS DLS is offline
I'm not sure of your question ... have you read through this entire thread and followed the links to other threads that have very good pictures / explanations? If not doing that should answer your question.
If I follow you correctly you are asking about cutting your bumper cover to install fog lights? You don't need to cut anything. There are covers over the fog light holes that are held on with a single bolt (10mm head size). You remove this bolt (save it as you use it to attach the light) pop out the cover then install the new fog light in the now open receptacle.
If you are pre-wired you just find the connector and plug it into the light. If not you will need to run a power and ground, but this is easy and uses standard wire (so no there is nothing pre-made for sale, again look through the forums here for pictures).
If this doesn't answer the question I apologize, let us know and we will try again.
  #229 (permalink)
Old 01-28-2013, 02:08 AM
2 door 2 person limit
I have a 2012 altima coupe base model and mine somehow is per-wired. Lucky me
