Prewired for fog? How to check. - Page 3 - Nissan Forums : Nissan Forum
  #31 (permalink)
Old 01-23-2008, 06:26 PM
cvtfan's Avatar
Any Canadian Altimas NOT pre-wired?
: 2007 Altima 2.5S CVT w/ Convenience Package : 2004 Mazda 6 Sport Wagon w/ Sport Package : 1996 Rocky Mountain Hammer Race :
  #32 (permalink)
Old 01-23-2008, 08:35 PM
zerodeefex's Avatar
any Canadian hybrid owners know if their cars are prewired for fogs (if someone would check that would rock)?
07 Super Black Altima Hybrid
aluminum kickplates (way cheaper than the dealer was asking)
clear bra
all weather floor mats
adding fogs
  #33 (permalink)
Old 01-23-2008, 11:42 PM
i am going to my dealer tomorrow and i am gonna have a lot of questions about auto dimming mirrors Navigation and Fogs. i will let you know what information do i get from there
08 Nissan Altima 2.5S Blue
07 Honda Civic Coup Si loded w/17" rims tinted Majestic Blue
06 Nissan Z350. Manual w/ 20" spiners Carbon Modified Hood and low lights.
07 Benz S550 Loaded
06 Cadilac Esclade
05 cadilac CTS loded.
00 Honda Accord EX
02 Range Rover. Sold.
07 Yukon Denali.
Damn Man I love some rides. Ferari is my next approach
  #34 (permalink)
Old 01-24-2008, 12:10 AM
cvtfan's Avatar
Did you already check your own car? The diagram on page 1 of this thread indicates a wire at pin 86/87 would indicate "pre-wired". As well, if any CANADIAN Altima Hybrid owner IS pre-wired, your CA Altima still may not be due to geographical reasons.
  #35 (permalink)
Old 01-24-2008, 01:59 AM
zerodeefex's Avatar
Already checked my car I was asking to see if anyone had the wiring. If that was the case, I was going to talk to my contact at the service department at a Canadian dealership to see if I could get the wiring harness from them.
  #36 (permalink)
Old 01-24-2008, 05:48 AM
scrutmonkey's Avatar
Fatty McFat fat
Figured mine wasn't....2008 california hybrid....not pre-wired. just thought I would share the info.
  #37 (permalink)
Old 01-24-2008, 05:57 AM
Nissan4LIFE's Avatar
April 2010 NOTM Winner
Damn I have the Loaded 2.5 SL with Tech package (Nav, Bose, the works) and no pre-wire...bummer. Someone should try getting the stalk and wire to those empty locations to see if it would work. I'm not getting fogs anytime soon or I would try it myself since I'm waiting on the body kits.
2007 Altima 2.5 SL CVT Radiant Silver
Error - Amount of MODS exceeds space provided. Click for CarDomain
Sponsored by: BlueBatmobile.net "AUTHORIZED INSTALLER" | AIT Racing | Racingline | Killerglass | Clear-Pro Invisible Auto Bra | V-LEDs
Threads: Subwoofer Enclosure | Air Suspension | Carputer
Immaculate Stylz on Facebook: http://www.facebook.com/ImmaculateStylzCC
  #38 (permalink)
Old 01-24-2008, 06:00 AM
QR's Avatar
QR QR is offline
Second to none
if you're getting the body kit then i would mount some universal ones behind the bumper
  #39 (permalink)
Old 01-24-2008, 06:05 AM
Thats what I'm going to do but I really didn't want the hassle of running wires through the firewall yet again...just running the 4ga for the amp and airbag compressors, not to mention all the sensor/valve wires through there was hell enough. I also do not have a good location inside the car to mount a switch so I would like to use the factory stalk and if I can't get it to work then I just won't install lights at all.
  #40 (permalink)
Old 01-24-2008, 02:06 PM
According to service manual, factory stalk is digital switch (mean no additional wire is needed to switch itself) and electronic block is ready to serve fog lights. So if you install factory stalk with fog, 86/87 connectors will have power. This will get rid of headache with installing aftermarket switch, relay and fuses. Just run wires from connector 86 and 87 to fogs (one wire to left fog and one to right fog). Additionally you will need to run wire to ground (electrical ground) :-), then attach connector and install fog lights itself.
  #41 (permalink)
Old 01-24-2008, 07:50 PM
zerodeefex's Avatar
Where would we ground the fogs? I am going to try to add 86/87 to that connector, then run the wires down with the headlamps, find a ground for the lights, and see how well that works. The only other thing for me now is to find a factory stalk.
  #42 (permalink)
Old 01-24-2008, 08:22 PM
I think the good way to go is to purchase stalk switch at dealership parts store. Then install the switch and test if the power on connector’s 86/87 appears. It should but you know… service manual may have errors.
If power appears then continue with wiring stuff and locating good point to connect ground. If it NOT appears, then return switch to dealership and get money back.
I'm going to do this way but not now, because it's very cold outside.. :-)
If you try it let us know how its works.
Thanks.
  #43 (permalink)
Old 01-25-2008, 03:46 AM
phat ndn boi's Avatar
I understand the 86/87 thing...but wherewould the wires be located if I had them??? under the windshield reservoir???...and if i dont have it how do i install the fogs???
  #44 (permalink)
Old 01-25-2008, 01:46 PM
Basically ground connector can be attached to any bolt which is tie to metal. It can be on engine or vehicle body or run wire directly to battery. May be good thing is to locate where headlamps connect its ground. If you want to do it as factory install you will have to run wire to engine harness itself, but it will be more work to do. You can trace the harness and locate where ground is connected. It should be on both sides of the engine room on the top. If you need picture I can send it to you.
  #45 (permalink)
Old 01-25-2008, 04:51 PM
zerodeefex's Avatar
I was thinking intake or drop-in HID kit with some relays next month. Looks like I'm going to be debating either or those with a turn signal stalk...
I think I might just do the stalk because I have the fogs sitting here! If I do, I'll take pics and do a write-up. It might not be the best, but I'll see what I can do.
