Prewired for fog? How to check. - Page 4 - Nissan Forums : Nissan Forum
  #46 (permalink)
Old 01-25-2008, 09:30 PM
08 2.5 w/ Convenience Package not prewired.
'08 Nissan Altima 2.5 Coupe
5% Tint, Debadged, 18" Stern ST-1's.
Rims for Sale!
http://www.nissanclub.com/forums/whe...els-tires.html
Altima Sedan Fogs for Sale!
http://www.nissanclub.com/forums/gen...ml#post3501626
  #47 (permalink)
Old 01-25-2008, 09:45 PM
Sorry for the double post...
This sucks, people that shelled out extra cash for their bullshit packages should get the fogs.
Styling/Functionality
Aluminum hood
Automatic on/off headlights [CP]
High Intensity Discharge (HID) xenon headlights [PP]
Fog lights 2
I was just looking on the Nissan website and under fogs for the 2.5, if you click on that number 2 on the website it says:
2 Requires 2.5 S Convenience Package. Late availability.
That means the 2.5S coupes w/ convenience package on the lots right now have fogs. That sucks.
  #48 (permalink)
Old 01-25-2008, 09:50 PM
zerodeefex's Avatar
Aluminum hood
Fog lights 2
at least you folks can get fogs. It doesn't come with any of the Hybrid packages, even the tech package. As a matter of fact, you can't get HIDs either. I tried to find where there would be an inordinate draw on the hybrid battery, but I'm seeing little to no effect on that, so that really bugs me. Oh well, going to do it all by hand sometime in the next two months and make a write up
07 Super Black Altima Hybrid
aluminum kickplates (way cheaper than the dealer was asking)
clear bra
all weather floor mats
adding fogs
  #49 (permalink)
Old 01-25-2008, 10:52 PM
phat ndn boi's Avatar
yeah can u put pics up of where things r located???...where does it get the power tht it needs???...straight from the battery???
  #50 (permalink)
Old 01-26-2008, 04:18 PM
raging56's Avatar
Raging56
I have a 2008 2.5 S Manual Sedan. If I checked it right then I do have pre-wired fogs. Is that diagram good for 2007-2008? I had to remove a white plug and I saw the pins that a wire would/could hook into. I at the 86/87 location. I assume that is pre-wired?
So, at this point I need to just install the switch and some fog lights and hook the fog lights up to the 86/87 pin and I'm good to go?
  #51 (permalink)
Old 02-04-2008, 10:30 PM
Originally Posted by algor View Post
Basically if you run two wires by yourself from fogs (aftermarket or OEM) to pin 86 and 87 (left/right fog) through factory wire holders. Then replace switch with it should work as designed.
Had to bump. Just ordered the OEM fogs off ebay, and will need this post handy when they arrive.....
  #52 (permalink)
Old 02-05-2008, 02:18 AM
Arrow
Basically ground connector can be attached to any bolt which is tie to metal. It can be on engine or vehicle body or run wire directly to battery. May be good thing is to locate where headlamps connect its ground. If you want to do it as factory install you will have to run wire to engine harness itself, but it will be more work to do. You can trace the harness and locate where ground is connected. It should be on both sides of the engine room on the top. If you need picture I can send it to you.
yeah can u send me pics of where the harness is located..because I have the 3.5 and its prewired but i just cannot find those harnesses at all...pics would be great thanks....
  #53 (permalink)
Old 02-05-2008, 05:10 AM
Jose3.5's Avatar
The passenger side one is near the windshield washer fluid tank the other one I don't know because I didn't look for it.
Stillen Kit http://www.nissanclub.com/forums/new...p-spoiler.html
4th Gen Exhaust Thread http://www.nissanclub.com/forums/eng...r-exhaust.html
2007 Altima 3.5 SE
  #54 (permalink)
Old 02-09-2008, 02:13 PM
Hi All,
How to check, that your car is prewired for fog lamps.
1) Open Realy/fuse block (IPDM E/R in engine room)
2) Locate connector showed on picture
3) If you have wire connected to pin 86 and 87. That mean your car is prewired.
Have fun!
Let's say if my car prewired (08 altima 2.5 SL Canadian Model) do I still need the switch or stalk? Where can I get them and how much they go for? Thanks....
  #55 (permalink)
Old 02-09-2008, 06:02 PM
JaGz120's Avatar
JaGz
My car is Pre-Wired
It's a 2007 2.5 SL I didn't get it new. Dealer said it was the ones they drive around, But I think it had a previous owner but they were BSing me.
2007 Altima 2.5SL
-Xentec 5000k HID Lows
-2009 Fog Light Kit
-35% Tints all around
  #56 (permalink)
Old 02-10-2008, 09:57 PM
larrythewanker's Avatar
My car is also pre-wired...Its a 2008 2.5 SL ... Bought it new Feb.2/08.
Edit: I purchased the car from a Brampton Ontario dealer...Brampton is just northwest of Toronto.
  #57 (permalink)
Old 02-18-2008, 03:11 PM
Yeah just checked my 2008 SL, it's not prewired.
Dark Slate 2008 Altima 2.5SL
No car note = #winning. New set of Nexen 5000 Tires, Alpine CDA-9887, Kenwood KAC-X10D & KAC-X40, JL Audio CS213RGW1V, Racingline strut tower brace, 35% Tints, Stillen Rear Sway Bar. Hushmat on trunk, side panels and rear deck.
  #58 (permalink)
Old 02-18-2008, 08:00 PM
Altima_Weapon's Avatar
I'm prewired, 2.5s and they told me my Alti is as base as they get.
  #59 (permalink)
Old 02-18-2008, 09:23 PM
For those that has oem fog and pre-wired, how do you installed the switch? or can you just get the stalk?
  #60 (permalink)
Old 02-19-2008, 09:17 PM
08 2.5SL pre-wired
CND 2008 2.5SL is pre-wired.
