The LED Q&A Thread - Nissan Forums : Nissan Forum
Old 02-25-2009, 08:40 AM
BT's Avatar
BT BT is offline
Super Modder
iTrader: 8 reviews
The LED Q&A Thread
Q&A Locations in Thread
Suggested V-LEDS replacement bulbs for 02-06 Altimas
http://www.nissanclub.com/forums/ult...ml#post3697074
Suggested V-LEDS replacement bulbs for 07+ Altimas
http://www.nissanclub.com/forums/ult...ml#post3697075
Q- 'How do I replace keyring light(02-04 Altimas)?
-----A- http://www.nissanclub.com/forums/200...ml#post3697747
Q- 'How does the dimming circuit on the dome light affect LED bulbs?'
-----A- http://www.nissanclub.com/forums/200...ml#post3697628
Q- 'How do I change the color of the shifter?'
Q- 'Can I change the color of the gauge cluster?'
-----A- http://www.nissanclub.com/forums/200...ml#post3710029
Q- 'How can I increase the reflectiveness of a bulb housing?'
-----A- http://www.nissanclub.com/forums/200...ml#post3713218
Q- 'Any idea why my glove box light does not work?'
-----A- http://www.nissanclub.com/forums/200...ml#post3721929
Q- 'How do I change the key ring bulb in an 05/06 Altima?'
-----A- http://www.nissanclub.com/forums/200...ml#post3726115
Q- 'What kind of resistor do I need for my LED turn signal bulbs?'
-----A- http://www.nissanclub.com/forums/200...ml#post3733545
Q- 'How do I wire in the turn signal resistors?'
-----A- http://www.nissanclub.com/forums/200...ml#post3745388
-----http://www.nissanclub.com/forums/200...ml#post3752543
Q- 'How do I replace the license plate bulbs?'
-----A- http://www.nissanclub.com/forums/200...ml#post3889886
-----A- http://www.nissanclub.com/forums/200...ml#post3747446
Q- 'How do I replace the glove box bulb?'
-----A- http://www.nissanclub.com/forums/200...ml#post3751850
Q-'How do I run wires for LED lights inside of the mirrors?'
-----A- http://www.nissanclub.com/forums/200...ml#post3768645
DIY Underhood lighting
----- http://www.nissanclub.com/forums/200...ml#post3780359
---Available here;
-----BT Design Underhood light kit 02-06 Altima - Lighting & Accessories - Racingline Performance
Q-'How can I change the bulb in my heated seat switches(02-04)?'
-----A- http://www.nissanclub.com/forums/200...ml#post3781082
Q-'HELP, I installed my LED interior lights and blew a fuse...Which one is it?'
-----A- http://www.nissanclub.com/forums/200...ml#post3824609
Q-'My dome light stays dimly on all the time, what is causing it?'
-----A- http://www.nissanclub.com/forums/200...ml#post3826166
Q-'How do I install the V-leds license plate frame on an Altima?'
-----A- http://www.nissanclub.com/forums/200...ml#post3809014
Q-'How can I fix the way my map light is facing on a 3rd gen car....or the map light is loose in the holder?'
-----A- http://www.nissanclub.com/forums/200...ml#post4001021
DIY 4 Door step/courtesy lights
-----http://www.nissanclub.com/forums/200...ml#post3826862
---How To:
-----http://www.nissanclub.com/forums/200...ml#post3830468
---Updated!!!
-----http://www.nissanclub.com/forums/ult...ml#post4139275
Information about Footwell Lighting
-----http://www.nissanclub.com/forums/200...-kit-pics.html
---Available here;
-----02-06 Altima BT Design Footwell Lighting Kit - Racingline Performance
Using strip lights to replace the trunk light
-----http://www.nissanclub.com/forums/200...ml#post3855964
---Available at;
-----BT Design Trunk illumination kit - Lighting & Accessories - Racingline Performance
Frankensteined 2002/3/4 3.5SL
Other Pics
My NC Garage
My Feedback Thread...
The Following 3 Users Say Thank You to BT For This Useful Post:
Old 02-25-2009, 08:41 AM
BT's Avatar
BT BT is offline
Super Modder
iTrader: 8 reviews
3RD Gen Replacement Bulbs
The list below fits the 02-04 Altima. The only differences on the 05-06 Altima aree the RED rather than amber rear turn signals, and the H11 rather than 9006 foglights. These are all basically stock replacements that plug directly in. If you are looking for a different color, note the product description and look on V-LEDS' site. The technolgy on LED bulbs is constantly evolving...as newer bulbs that work or look better are released, I will update the links and add an edit date next to them.
To view pictures of the lights in my '04 Altima, http://www.cardomain.com/ride/3074232/2
Low beam headlamp
H1- I am using 5k Blue
Xenon-D2R
High beam headlamp
9005
Fog Light
9006
Parking light/ Front turn signal-UPDATED 3-2012
1157-Amber
AMBER 7.5W HIGH POWER LED TURN SIGNAL BULBS 1157 2057 | 1 PAIR
Rear turn signal-UPDATED 3-2012
3156-Amber
AMBER 7.5W HIGH POWER LED TURN SIGNAL BULBS 3157 3156 4057 | 1 PAIR
Stop/Tail light-UPDATED 3-2012
3157
RED 7.5W HIGH POWER LED TURN SIGNAL BULBS 3157 3156 4057 | 1 PAIR
3rd Brake-Rear Window UPDATED 3-2012
921
RED 14 5W HIGH POWER 3RD BRAKE LIGHT BULB T15 T-15 516 579 901 904 906 908 909 912 914 915 916 917 918 920 921 922 923 926 927 928 939 | 1 EACH
License plate UPDATED 3-2012
168
5K WHITE 3 CHIP 5 LED LIGHT BULBS 194 168 158 2821 | 1 PAIR
Back up light-UPDATED 3-2012
912
5K WHITE 19 LED 8W HIGH POWER BULBS 917 918 920 921 922 923 579 | 1 PAIR
Rear sidemarker
168
RED 6 LED FLANK BULBS 194 168 158 2825 | 1 PAIR
Glove box
168
6K WHITE 6 LED FLANK BULBS 194 168 158 2825 | 1 PAIR
Map light
57
*Please read*
http://www.nissanclub.com/forums/200...ml#post4001532
6K WHITE HIGH POWER FLANK LED BULBS 1895 53 57 BA9s | 1 PAIR
Dome light-UPDATED 3-2012
DE3175
5K WHITE 1.5W 3 LED HIGH POWER UNIVERSAL DOME LIGHT BULB 31-36MM ADJUSTABLE
Step/Courtesy light
168
Trunk/Cargo area UPDATED 3-2012
168
Vanity UPDATED 3-2012
5K WHITE HI POWER 3 CHIP 2 LED VANITY SUN VISOR LIGHT BULB
Key Ring
74
6K WHITE 3 LED WEDGE BASE DASH LIGHT BULBS 37 74 | 1 PAIR
Dash Turn Signals
74
GREEN 3 LED WEDGE BASE DASH LIGHT BULBS 37 74 | 1 PAIR
Turn Signal Resistors
Blinker/Warning Fix - Turn Signal Fix
NOTE: If you are doing just the front or rear with LED bulbs, use the 6 ohm resistors. If you are doing both front and rear, use the 3 ohm
Old 02-25-2009, 08:42 AM
BT's Avatar
BT BT is offline
Super Modder
iTrader: 8 reviews
4th gen replacement bulbs
There are a couple of posts on the Gen4 board using different bulbs than the ones recommended below. These are the ones that I personally installed into an 07 sedan. Just like the lists for the 02-06 Altimas, all of these refer to white bulbs for the interior. If you are after another color, V-LEDS probably has them.
**Note: V-LEDS recently started stocking 2 different colors of white bulbs for many applications. They are now offering 6k and 5k. 6k is a slightly blue color and a 'cool' white, while 5k is more a 'warm' white.
Interior
-Map Lights, 194/168 UPDATED 3-2012
Front/Rear
http://www.v-leds.com/Interior-LED-B...84280-1-2.html
-Vanity Lights, no# UPDATED 3-2012
http://www.v-leds.com/Interior-LED-B...68538-1-2.html
-Door/Puddle Lights, 194/168
V-LEDS HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825
-Glove Box, 74
http://www.v-leds.com/Interior-LED/G...98403-1-2.html
-Trunk Light, 194/168
Trunk Lighting Kit
-3rd Brake Light, 921
1 EA V-LEDS RED 14 M-SMT 5W HIGH POWER 3RD BRAKE LIGHT BULB
Exterior
-License Plate Lights, 194/168 UPDATED 3-2012
-Reverse Lights, 921
HID WHITE 19 M-SMT 8W HIGH POWER BULBS
-Stop/tail Light, 3157 UPDATED 3-2012
http://www.v-leds.com/Exterior-LED-B...93176-1-2.html
-Rear Turn Signal Light, 3156 UPDATED 3-2012
-Rear Marker Light, 194
http://www.v-leds.com/Exterior-LED/P...04683-1-2.html
-Front Turn Signal, 3457 UPDATED 3-2012
http://www.v-leds.com/Exterior-LED-B...93082-1-2.html
-Front Marker Light, 194
http://www.v-leds.com/Exterior-LED/C...14825-1-2.html
Old 02-25-2009, 04:19 PM
I would like to install white color LED lights inside, but I have a concern. When the doors close, I notice the stock bulbs dim. Since LEd lights don't dim, will this cause a problem?
Old 02-25-2009, 05:34 PM
tuffguy515's Avatar
How do I replace the light on the ignition key? ...sorry if this has been answered before but i thought it be a great question to add to the thread...does it just pop open?
http://www.youtube.com/user/tuffguy515
...it beats walkin
Old 02-25-2009, 07:12 PM
nissan_2003's Avatar
Alti_junkie
To change the ignition light is really really easy. Remove the circle cap thing that goes infront of the ignition it just pops off. Then You will have to remove the plastic piece that goes under the steering rack. Only to screws hold it in place. They are located well one is all the way on left corner the other is on the right corner you will see it. To access the left one you will need to remove the fuse box lid. The it will come off. Disconnect the dimmer switch. You will see the clear circle that lights up on the ignition. Just wiggle it lose once it comes off you will see behind a type or bulb that is screwed on. Just turnit counter or clockwise I forgot and the bulb will come out. Just pull the bulb out it will have this weird type of skin on the bulb type of material. Then just insert LED and put everything back together. If this is confusing just say what it is and I will try to do a write up.
My car stock to the Xtreme but will get modified eventually
My new babes 1995 Eclipse GS-Turbo updated to 16g turbo still has sidemount intercooler . Just found out this eclipse was converted to AWD,
Old 02-25-2009, 09:22 PM
fourtwenty's Avatar
Nothin' On Me
i did a small search and couldnt find anything about replacing the lights under the shift knob. the orange lights is so dim you cant even tell there is a light on.
i have blue LED bulbs from vleds so this would finish the look =]
2006 Black Altima 2.5S SER conversion | powdercoated SER Wheels | Nismo CatBack | InJen CAI | Eibach Pro-Kit | KYB GR2 Struts/Shocks | Stillen FSTB | Active Tuning S5 Grill & Grounding Kit | RL Hood Struts |Viper Remote Start | Alpine W505 | Alpine Type X Components / 5.25 & 6x9's- PDX 4.150 * 1000.1 | JL w7 13.5 Sig Series | RearView Camera w/ 7" LCD| 120 Sq Ft Megamat & 1 gallon eDead v3| YellowTop |
Old 02-25-2009, 09:49 PM
hattrick3518's Avatar
Winner March 2010 NOTM
i think that the bulbs them selves are white, there is an orange film on the numbers or somewhere in there if i recall correctly from bill...
Stock
Old 02-25-2009, 10:25 PM
tuffguy515's Avatar
cool thanks a lot.
Old 02-25-2009, 10:46 PM
What about my question regarding the stock lights dimming.^
Old 02-25-2009, 10:50 PM
UzumakiNaruto's Avatar
i got the dome light and its been holding up so far on the dimming. I mean leds can handle "on/off" a lot theres no heat or somehting.
Altima 2005 3.5 SE: Berk v2 Intake, 3000k/5000k Hid Fogs,Se-R Tails, s5 clone grill, Vibrant Dual Catback Exhaust,Racing Line FSB ,Slotted Front Rotors, White LED eyebrows,Clone Se-R Headlights w/5000k Crystal Vision Philips HID's and BT's White footwell LED's.
Old 02-25-2009, 10:53 PM
tuffguy515's Avatar
LEDs dont dim? ...u mean when u have the door open the interior lights go on correct? and when u close the door they turn off correct?
LEDs should work the same way. They go on when u have the doors open, and turn off when doors are closed. and also, they will last u a long time, so they wont dim or die out as fast as regular bulbs
ive had all my LEDs in my car for a year now and theyre just like new
idk if thats wat u meant. correct me if im wrong
Old 02-25-2009, 10:58 PM
Well yes in a way. The stock bulbs slowly dim off when you just close the doors. Will this decreasing current cause any problems to the LED bulbs like flickering?
Old 02-26-2009, 12:22 AM
tuffguy515's Avatar
i doubt any flickering will happen..at least from wat i have experienced wit my LEDs.
I have them on license plate, dome light, glove compartment, trunk, and as courtesy lights...and no flickering wat so ever. And its been bout a year
Old 02-26-2009, 01:19 AM
mazda6's Avatar
great write up, maybe needs picture for some people
should be stickied
Powered by vBulletin®. Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
