Daytime running lights - Nissan Forums : Nissan Forum
post #1 of 11 Old 04-08-2011, 02:46 AM Thread Starter
Hello Guys,
Does anyone know how to activate the Daytime Running Lights on the 2007 Altima. I moved from US to Canada and looking to import my car to Canada. I have to pass the canadian standards to register my car here. How difficult is it to activate the DRL.....Can I activate them on my own or do I need to go to a service garage.
Any help would be greatly appreciated.
altimaguy2007 is offline
post #2 of 11 Old 04-08-2011, 03:07 AM
Common sense advocate
monster289's Avatar
Quoted: 31 Post(s)
Move back to the US.
To the best of my knowledge DRL's are not required on US vehicles.
Sounds like you should call a Nissan dealer in Canada. They should be able to help you.
monster289 is offline
post #3 of 11 Old 04-09-2011, 04:46 PM
The dealership can use the Consult III to go into the BCM and turn on the DTRL option. Fairly easy but they may charge you the fee for 1 hour labor.
ADAMECHANIC is offline
post #4 of 11 Old 04-09-2011, 07:34 PM Thread Starter
Thanks ADAMECHANIC. I spoke to the Nissan Dealership and they said that your car doesn't even have the DRL lamps so they can't do anything. Canadian Tire says that they have to install a module to turn DRL on.
So, do US cars have the DRL lamps or not?...I am totally confused.
post #5 of 11 Old 04-09-2011, 08:32 PM
I'll look more into it on Monday when I go to work. I'm fairly certain you simply activate the IPDM and BCM to operate them. You may have to install a relay though. I'll check and let you know.
post #6 of 11 Old 04-09-2011, 09:07 PM
Some US cars have DRL. I had a 08 Civic and that had DRLs. It was either when you turned on the car or had the parking break down (can't remember exactly) the DRLs would come on if your headlights weren't already on. The US Altima doesn't have this.
AznGuy is offline
post #7 of 11 Old 04-13-2011, 07:57 PM
Quoted: 1 Post(s)
This shouldn't be too difficult to do. There is a dealer here in Vegas that installs DRLs on all their new cars. Mostly so they can charge for something you didn't ask for, but whatever. It can be done to US spec cars. Just need the right kit.
Audentes Fortuna Juvat-Fortune Favors the Bold
kemer1 is offline
post #8 of 11 Old 04-13-2011, 10:26 PM
I checked on this. It has to be activated in the BCM like I said and a specialized relay has to be installe into the harness up by the washer fluid neck. Per Nissan North America that relay is not for sale or distribution in the United States. You must take your car to a Canadian dealer to have this performed. I was also told that the DTRL's are your brights at half voltage so it is a relay different from any we have. I couldn't even get a part number from them. Sorry and good luck.
post #9 of 11 Old 04-14-2011, 02:37 PM Thread Starter
Thanks ADAMECHANIC. I got the DRL finally installed from Canadian Tire as they were the cheapest. It cost me $190 total for both parts and labour included. The Nissan dealership was asking for $400 for the same. Hopefully this helps peepz who bring Vehicles from US to Canada in future.
I appreciate the replies from other Altima owners.
post #10 of 11 Old 04-14-2011, 05:51 PM
Blackmobile
Tonychanman's Avatar
you could have wired your foglights to come on whenever you turn on the car to act as the drl's.
2008 2.5S Coupe Super Black purchased 07/15/08
Debadged | White & Blue LED's | 20/35 Tint | Tinted Tails | Lip Spoiler
DDM 6000k HID's | Autopia Fogs | Blue Footwell lights | Razo RA96 Shift Knob
Racingline RSB, FSB, Sorth Throw Shifter, Grounding Kit, & Rear Endlinks
19" G35 Forged Ray's wrapped in Potenza RE050A
Tonychanman is offline
post #11 of 11 Old 04-14-2011, 09:40 PM
tt85_GM's Avatar
I disabled my DRL, I removed the fuse as I like to run with just parking lights or the HID's. and Im prety sure you dont need DRL's for a safety inspection, but it could be different for bringing cars into Canada.
-'08 Altima Coupe 2.5 CVT
-Stillen front lip, Stillen rear spoiler, 6000k Migo VX2 HID's, Eibach springs, Powerstop drilled/slotted rotors, G37 wheels
tt85_GM is offline
