Sorry, coming back to this. I'm only intrigued by it because on my older '04 Mazda3 that I had, I was able to order a replacement lighting unit to go in my 3rd brake light that had many LED bulbs in it. Is there any replacements for a 2008 Altima's high mount brake light to have LEDs (not the cheap LED light bulbs found on most sights. I find those to be very dull during the day).
My other thought was somehow modifying an '09 Coupe's light to fit in my '08 sedan somehow. Think that's possible?
2009 Nissan Altima Coupe Used Third Brake Light Black | eBay
Any other recommendations?
Originally Posted by DLS
Did you private message BT as suggested? If anyone here would have an answer it would be him.
Hey DLS. I did PM BT and he recommended that I get some lights like:
2 20 pcs 9W LED High Power Eagle Eye Rear Back Up Reverse Tail Light Lamp New | eBay
I ended up getting a red one of these, however it does not fit in the light bulb housing on my car, so it's just sitting in my house. The only way I could fit it inside the light mounting is to drill the hole where the bulb goes. Even then, it would not be held into place, it would just be rolling around in there.
