05 Altima no injector pulse - Nissan Forums : Nissan Forum
post #1 of 4 Old 05-16-2019, 03:09 PM Thread Starter
Wind82's Avatar
I have a 2005 Nissan Altima 2.5 that will not start .
History
For about a week the engine was running ruff tossing out a p0420 , i mail ordered an 02 sensor but the shit hit the fan .
After work I started the car , turned on the Ac and it just shut off and wouldn't come back on . I had the car towed home and started a diagnostic . Key on position 1 i can hear the fuel pump prime so i undo the quick connect under the hood to check if it's pumping fuel and it is. I plug in the obd2 scan tool and crank the engine to see if it reads rpms and it does . Next i checked for spark using a spark tester then spray carb cleaner in the Tb and it starts up long enough to burn off the cleaner. At this point i know it's fuel delivery so i test the fuel injectors then plug in a multi-meter set to dc voltage . I get 10 volts to each injector in key position 1 , the voltage drops to 8 or 9 volts on crank. For shits and giggles i changed the crank sensor anyway and it still wont start . I have no security light and no codes set or pending .
Anyone got any idea's what's going on ?
Always Serious
Wind82 is offline
post #2 of 4 Old 05-16-2019, 04:32 PM
d0ugmac1's Avatar
Quoted: 1154 Post(s)
How are you determining no injector pulse? I don't disagree with the diagnosis, just curious as it doesn't flow from your voltmeter test.
Could still be your Cam sensor. On these cars I believe the cam and crank sensors are the same part, so you could swap you new part in for the cam sensor and put the old crank sensor back in.
/ Brake Job / RA 5% Discount
d0ugmac1 is online now
post #3 of 4 Old 05-16-2019, 08:00 PM Thread Starter
Wind82's Avatar
You can't see the waveform of the injector pulse with the meter but you can see the voltage fluctuate between 0 and 12 volts . When i probe the injector plug while cranking the voltage actually drops and stays dropped while cranking . That combined with the fact i can spray in fuel and it runs until it burns shows me they are not firing . I have replaced both the cam and crank sensors yet the problem still persist .
Always Serious
Wind82 is offline
post #4 of 4 Old 05-17-2019, 12:15 AM
Quoted: 154 Post(s)
Until you do a numbers fuel pressure check it can be pump. Just because you got a discharge from the fuel line means nothing. MPFI has to have exact pressure to drive enough fuel to start and run, even 10 psi short can make it not start but you get fuel all day long out of the line at what you think is correct pressure.
amc49 is online now
You may post new threads
You may post replies
