I've been running the car up/down my driveway to test the transmission, and the brake pedal at low speeds is rock hard.
The brakes work, but its like pushing against a solid piece of metal.
I did the booster test where you turn the car off, pump the brakes then hold down, and start the engine. The pedal is supposed to go down just a bit when the engine is started, and mine did.
Today I checked the booster vacuum hose, and all was well with it, so I made a vacuum reservoir, and there was no change.
Seems that years ago I had that problem with a full size Ford LTD, and it was the master cylinder itself, but this was before anti lock brakes.
Anyone have this happening to their SER?
