I had a crack in my driver's side tail light so I picked up a new assembly online and swapped it out. Everything works, but as soon as I drove, my ABS, SLIP, and VSC lights all came on. They shut off when I restart, but come on after the brake is down for about 10 seconds. Any ideas if I have a bad assembly or what I might try to fix the issue?
Check your brake switch under your brake pedal, might need to be replaced, subaru’s Would go out around 50-60k miles and do the same thing. Or a bad ABS wheel sensor COULD ado the same thing, but being that you didn’t mess with the wheels, I doubt that’s what it is. Good luck!
Related Threads
The Nissan Club
4.4M posts
197.5K members
Since 2001
