08 3.5 Engine Knocking at cold start-up - Nissan Forums : Nissan Forum
post #1 of 12 Old 04-24-2019, 04:47 PM Thread Starter
Quoted: 2 Post(s)
I have read the posts for engine knocks but mine is a little diff. At cold s-up, knocks for 1-2 secs then ok. Hadn't noticed before but engine revs > 2k for a min or so even when weather is warm. I know it is supposed to rev higher when cold but could cause excessive wear if too high? Sounds suspiciously like a rod. Maybe a valve, but awfully loud. Using Mobile1 Syn 5w30. 112k
TIA
'08 Altima Sedan 3.5 All Stock.
tony4us10 is offline
post #2 of 12 Old 04-24-2019, 06:43 PM
d0ugmac1's Avatar
Quoted: 1149 Post(s)
Rod or big-end bearing. Try a oil change with (cheap) straight 40 oil. Does that make a significant difference in cold start noise? If so then bearing issue and you are now driving a ticking time bomb...you don't want to throw a rod at speed.
/ Brake Job / RA 5% Discount
d0ugmac1 is online now
The Following User Says Thank You to d0ugmac1 For This Useful Post:
post #3 of 12 Old 04-24-2019, 08:23 PM Thread Starter
Quoted: 2 Post(s)
I prefer not to throw one at all. Thanks man, I knew you would reply. You are such a help in here
Tony
Oh, and I noticed you have a Stillen sway bar. Did it help a bunch with body roll?
NM, duh. I read your post.
post #4 of 12 Old 04-25-2019, 10:59 AM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 94 Post(s)
Are you talking knock, or rattle. A lot of VQs have an issue with the timing chain rattle for a second or 2 at start up. I believe that issue is a tension er.. or something.....My 02 started to do this on occasion at under 30K
*Bumper Plugs
Garage:
* 91 MR2 37K miles 4 Sale
*04 Mini Cooper
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is offline
The Following User Says Thank You to wild willy For This Useful Post:
post #5 of 12 Old 05-01-2019, 11:46 PM
Doesn't that engine have variable valve timing or similar. If so it'll likely have little oil passages that 40W would starve, so I wouldn't recommend using any oil thicker than recommended.
That said, my 2006 with >280k miles rattled for a handful of seconds when started after the oil had drained to the pan. Rattled more so if oil was low (it burned oil).
Not sure how loud your noises are but mine was easily heard from inside the cabin with windows rolled up yet not loud enough to say "what the hell?!".
aperez is online now
The Following User Says Thank You to aperez For This Useful Post:
post #6 of 12 Old 05-02-2019, 02:25 PM
Quoted: 154 Post(s)
40W oil should not affect VCT timing devices at ALL. I have run it for 20 years in my Fords, everybody said it would mess the VCT up. Nope, not even a bit. STRAIGHT 40W on top of that.
Heavy oil messing up parts (dry starts) is a myth brought on by the oil companies to get you to fall for lower vis oils that cost more. They are for mileage ONLY.
I have been proving that for some 35 years now. Running 15W-40 in my Nissans now. No trouble.
amc49 is online now
The Following User Says Thank You to amc49 For This Useful Post:
post #7 of 12 Old 05-02-2019, 08:03 PM Thread Starter
Quoted: 2 Post(s)
Originally Posted by wild willy View Post
Are you talking knock, or rattle. A lot of VQs have an issue with the timing chain rattle.....
Sorry guys. I didn't see these replies. It may be a rattle I hope. Would prefer to replace timing chain. Or tensioner. Think I'll call dealer on cost of replacing chain. I've heard different opinions on replacing timing chain some say every 120k some say not at all.
Thanks guys.
post #8 of 12 Old 05-03-2019, 12:51 PM
Throckmorton's Avatar
Quoted: 133 Post(s)
Thanks guys.
I'm guessing that the Nissan dealer will give you an estimate of at least $1,000.00 for timing chain replacement, and related parts.
Me? I would drive the car and not worry about it. The timing chain tensioner is oil pressure activated, meaning it takes oil pressure to take the slack out of the timing chain.
"Owner's Manual is like a parachute...only works when opened."
Throckmorton is offline
The Following User Says Thank You to Throckmorton For This Useful Post:
post #9 of 12 Old 05-12-2019, 10:40 PM Thread Starter
Quoted: 2 Post(s)
It's been doin that for a while now, over a year. I hope it's just the chain, but in my experience with cars it sounds like a rod. Has that metallic sound. Just happens for a second. But if I pull away cold under load like uphill, I can hear a faint sound. Thanks guys for the help. I'm gonna just drive it. I will try the 40w and see if that quietens it any.
post #10 of 12 Old 05-14-2019, 02:53 AM Thread Starter
Quoted: 2 Post(s)
What does the check mark on this thread mean? I've looked but can't find what those marks mean. TIA
post #11 of 12 Old Yesterday, 04:02 AM
Quoted: 154 Post(s)
If talking about to the right in current threads it likely means you have just already read that one today.
If you know anything about rod knock you'll know they don't knock for a year. Timing parts likely.
amc49 is online now
post #12 of 12 Old Yesterday, 05:06 AM Thread Starter
Quoted: 2 Post(s)
Thanks. That was the check I was talking about.
Again, it only knocks at cold start, almost immediately quietens . Never really had a rod bearing or any bearing do that. And it's maybe faster than a rod noise would be. But that's the way it sounds. But it could be a rattle that sounds that way. I hope it is timing parts. I've been confuzzled over it. That's why I posted. I had a '65 Mushorse that knocked for as long as I had it (several years). I expected it to throw at any time, but it held on. Someone totaled it for me LOL.
Thanks again.
