Steering banjo bolt leak - Nissan Forums : Nissan Forum
post #1 of 4 Old 04-14-2019, 09:57 PM Thread Starter
speedy Luna's Avatar
Hey all,
I used dye and can see that I have a dripping leak from the banjo bolt, I'm presuming leads to the pump? Anybody know the fix for this? Just order a new high pressure hose?
speedy Luna is offline
post #2 of 4 Old 04-15-2019, 11:14 AM
d0ugmac1's Avatar
Quoted: 1137 Post(s)
Is the banjo fitting leaking, or is it running down from somewhere? If just the banjo...you might get away with some new crush washers after a good clean of the fittings. If the hose is rotten, or the crimp is leaking...yes, new hose required. Make sure you get the right type of fluid...I know my Altima uses Dexron VI ATF as the equiv to Nissan OEM steering fluid.
/ Brake Job / RA 5% Discount
d0ugmac1 is online now
post #3 of 4 Old 04-19-2019, 04:14 PM Thread Starter
sir,
given the pic for reference, what advice would you give? thank you again for your time
Click image for larger version
post #4 of 4 Old 04-19-2019, 07:56 PM Thread Starter
disregard that pic, I misinterpreted the teflon as dye... the pic I posted is the pressure sensor...
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN MAXIMA FORUMS > 2009 - 2014 Nissan Maxima Gen. 7 Discussion
