Lugnut Torque - Page 2 - Nissan Forums : Nissan Forum
post #16 of 27 Old 11-22-2002, 07:55 PM
*Donating Member* Member
mwessinger's Avatar
Quoted: 5 Post(s)
I picked mine up from Sears a few years ago. Half-inch, so I picked up some metric and standard deep-well sockets to go with it. Spent less than a hundred on the whole setup.
Mike
2012 370Z (The Weekend Car)
2015 Altima 2.5 SV (Daily driver)
2012 Altima 2.5 SL (was mine-wife's now)
1965 Chevy C10 Stepside
mwessinger is online now
post #17 of 27 Old 11-22-2002, 09:58 PM
GR
carfreak67's Avatar
Maybe I just over-do things but I've got 3 different torque wrenches.
One I use if torque isn't abosultely positively critical and there is a chance that I may drop the wrench because of where the bolt is. That way if I drop the wrench I haven't ruined a really nice torque wrench.
The other two are very nice torque wrenches that I treat like they're made of glass. I'm sure dropping one a few times isn't good for their calibration.
One is a 3/8 drive and is for smaller torque jobs and the other is a 1/2 inch drive for items over 85ft/lbs.
Like I said, maybe I just tend to be too anal when it comes to my cars.
carfreak67 is offline
post #18 of 27 Old 12-12-2002, 07:05 PM Thread Starter
Willy is right here is a link to harbor freight:
http://www.harborfreight.com/cpi/cta...temnumber=2696
guiseppewv is offline
post #19 of 27 Old 12-12-2002, 07:12 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 96 Post(s)
[QUOTE]Originally posted by guiseppewv
[B]Willy is right here is a link to harbor freight:
Willy don't lie] Thanks for coverin my ass
*Bumper Plugs
Garage:
* 91 MR2 37K miles 4 Sale
*04 Mini Cooper
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is online now
post #20 of 27 Old 12-12-2002, 07:28 PM
TALL member
i haven't read the manual but i was taught to always torque the lugnuts to 80lbs/ft or torque on any car
My VB Garage
My 3.5 Altima, 9/21/03-7/30/06
My 2.5 Altima, 11/24/01-8/2/03
SHIFT_this
Gunmetal 3rd Gen crew
14.2 @ 96mph with Intake, Exhaust, UDP
TweekersAltima is offline
post #21 of 27 Old 12-12-2002, 07:49 PM
page 6-5 of the owners manual clearly states 80lbs torque for the lug nuts. It is very important that the torque is correct or you could cause the rotors to warp
pcsgrp35se is offline
post #22 of 27 Old 12-13-2002, 03:31 PM Thread Starter
Tweeker: I am pretty sure that my last car, a Z-24, stated 100 ft-lb of torque, in the manual. I replaced the brakes on my sisters Accord 2 days ago and the torque was 80 ft-lbs in the manual.
post #23 of 27 Old 03-15-2003, 01:57 AM
mwessinger's Avatar
Quoted: 5 Post(s)
Talk about resurrecting the dead threads.
Anyway, I am at the point of needing to rotate the tires and of course first went to the FAQ 2002-2003 to find it and no luck. So I had to search and found this thread. Not a bad thing, but maybe one of the mods could put a "Torque Spec" thread in the FAQ. I did not remember the spec in the manual, but then again, it has been months since I read it, and the manual is in the glove box of the car.
In addition to the lug nut torque spec, maybe the FAQ addition could include other commonly used torque specs such as the drain plug, spark plugs, etc.
Just a thought.
Mike
post #24 of 27 Old 03-15-2003, 05:40 AM
Life, Liberty, Pursuit of
torque
being a mechanic for a nuclear power plant for the last 9 years, i know a little about torque.
umm, a great torque wrench for most of you is a 0-80 ft lb ratcheting "click type" 3/8" torque wrench. Buy a 3/8" to 1/2" drive adapter for it and it can be used for almost everything.
i have that and a 0-250 ft lb one and the only time i need to rent one is on some axle nuts that take 300 ftlb's
Altima ESM says 72-87 ft lb for the wheel lugs, while the wheel chart that Wal Mart tire and lube uses says 75-90 ftlbs.
80 is the target in both cases. remember to check the torque again after driving the car for a day or two as the heat from driving can loosen the lugs.
snolden is offline
post #25 of 27 Old 03-15-2003, 07:08 AM
every car has its own specification but i would go with the manuals 80 lbs. i usually go with what the manual recomends
Altima2.5S03 is offline
post #26 of 27 Old 03-17-2003, 01:35 PM Thread Starter
Just a thought.
This is a damn good idea. I would be willing to help gather specs if on of the mods decided that this is worthwhile.
post #27 of 27 Old 05-02-2015, 02:48 PM
Page 6-7 in my Canadian Owners Manual states, 113 N-m (83ft lbs). A good tip from the manual says its recommended that wheel nuts must be tightened to spec at each lubrication interval.
2013 Nissan Altima SV 3.5
Hope this helps!
threepoint5 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Nissan Tires, Wheels, Brakes & Suspension > ARCHIVE: Tires, Wheels, Brakes & Suspension Forum
