Nissan R35 GT-R City Light LED Replacements! Install Video! Plug & Play Installation! - Nissan Forums : Nissan Forum
post #1 of 1 Old 09-22-2016, 06:09 PM Thread Starter
Supporting Vendors
Diode Dynamics's Avatar
Quoted: 2 Post(s)
Arrow Nissan R35 GT-R City Light LED Replacements! Install Video! Plug & Play Installation!
Nissan R35 GT-R City Light LEDs
City light bulbs are used to illuminate the inner-portion of your headlight housing at night, and turn on with your parking lights. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the headlight with modern, cool white light. By changing your city light bulbs to LED, you can easily add this luxury look to your R35 GT-R!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your GT-R looks at night.
(HP3 Cool White)
(HP5 Cool White)
(HP36 Cool White)
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
HP36: Brightest option available (210 lumens)
Bulb Design
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your R35 GT-R).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
City Light LEDs for Nissan R35 GT-R (pair)
*Amber HP3
If you have any questions, please don't hesitate to post, PM, Email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Submitted Photo with HP5 Amber Installed
Diode Dynamics is offline
  Nissan Forums : Nissan Forum > Vendor Member Section > Diode Dynamics
You may post replies
