idling rough - Nissan Forums : Nissan Forum
post #1 of 8 Old 01-16-2015, 05:26 PM Thread Starter
Quoted: 1 Post(s)
idling rough
I have a 2011 nissan altima and its been idling rough for a little while now. It has gotten worse lately. It does when i am sitting at stop lights or drive thrus. When i put the car in park it stops. What could be wrong with it?
lacyrae is offline
post #2 of 8 Old 01-16-2015, 05:37 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
It is most likely worn/damages spark plug(s) and or coil is going bad. Could also be am intake manifold leak...a leak at the TB, etc. Did you check for codes yet?
4DZC is offline
post #3 of 8 Old 01-16-2015, 05:40 PM Thread Starter
Quoted: 1 Post(s)
I got new spark plugs last summer...yes no codes have came up...i had a small vacuum leak but that was supposedly fixed
lacyrae is offline
post #4 of 8 Old 01-16-2015, 05:43 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Double check it. Even a small leak can drive things crazy. The plugs still should be pulled and inspected. The PVC valve should be removed and checked to ensure it is moving freely and not clogged....
4DZC is offline
post #5 of 8 Old 01-16-2015, 05:45 PM Thread Starter
Quoted: 1 Post(s)
Ok...thank u so much!!! I will get it checked asap
lacyrae is offline
post #6 of 8 Old 01-16-2015, 05:48 PM Thread Starter
Quoted: 1 Post(s)
If it was a bad coil or intake shouldn't it do it all the time though?
lacyrae is offline
post #7 of 8 Old 01-16-2015, 05:50 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Not necessarily because with the coils the resistence changes with the load of the engine.
4DZC is offline
post #8 of 8 Old 01-16-2015, 05:51 PM
d0ugmac1's Avatar
Quoted: 1153 Post(s)
Coil should mostly be temp related though by no means isolated from the rest of the systems. Intake vacuum leak should be worst under load/no throttle, so putting it in park might make the difference between struggling and not.
EDIT: coils are just spools of copper wire, whose resistance changes with temperature, not vacuum. bEcause the length of wire is quite long in the spool, the effect is multiplied over what we normally see (extension cords, etc.)
http://hyperphysics.phy-astr.gsu.edu...ic/restmp.html
d0ugmac1 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > ECM / ECU Tuning
You may post new threads
You may post replies
