Hi - Nissan Forums : Nissan Forum
post #1 of 1 Old 04-07-2016, 02:55 AM Thread Starter
Hi
Iam not sure if this is the right place first time I have an 06 Nissan Titan which the fuse box by the battery post was corroded I didn't start one morning so I went to and cleaned it and tried to start and no power to the dash or ignition but yet I had power so I looked at the fuse box they were all good but it landed in side fuse box had separated a little bit... so I crossed it over with a copper wire and it started and it worked but now it has no power in Drive like it's not shifting down 2 1st once I get up to 30.. 50 has the same amount of power but starting off very sluggish and reverse has lots of power any ideas what this could be powertrain module.... limp mode ... Or mabye rest codes..any help would sure be appreciated
wildtrophys is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > ECM / ECU Tuning
You may post new threads
You may post replies
