Build your own pressure tester! - Nissan Forums : Nissan Forum
post #1 of 12 Old 02-23-2006, 02:40 AM Thread Starter
The Dude
ULTIMATUC's Avatar
sup boost heads?
I don't think I've ever done a write up, so here's a small and simple one.
*disclaimer*
This method of testing can be hazardous to your turbos seals. Please make sure to use a regulated air supply, and don't use more than 10psi! 10psi is more than enough to sniff out most leaks you might have. I just did my car, and I had one leak in a place I would have never thought would leak. go figure.
*supplies* (can be found at your local hardware store)
6"s of 2" pvc pipe
1 - 2" female adapter
1 - 2" cap to screw into female fitting
1 - super glue or epoxy
1 -1/4" male air fitting
1 - 1/4" brass nut (must be for a pipe thread!)
1 - your own coupler and clamps from the intake side of your system
Its all very self explanatory.
press the female adapter onto the pvc pipe. this is where the glue comes in. these pieces should be a press fit, but I'd suggest gluing them just to be safe.
now, drill a 7/16 hole in the top of the cap that screws into the adapter. (I used a tap to tap perfect threads, but you dont have to. the plastic is soft enough to where you can screw the fitting in.)
now clamp it all on the turbo, as you would your intake plumbing.
when you go to hook up your air supply, make sure to turn the pressure down all the way before hooking the hose up! this way you'll be able to increase the pressure ever so slightly, so that you wont damage your seals. ***DO NOT TRUST THE GAUGE ON YOUR COMPRESSER! YOU NEED AN AUTOMOTIVE BOOST GAUGE HOOKED UP TO THE SYSTEM!** I keep one in my tool box for this very purpose.
be careful doing this guys! its a simple way to detect boost leaks, but it CAN also reek havoc on your turbo.
ULTIMATUC is offline
post #2 of 12 Old 02-23-2006, 02:45 AM Thread Starter
The Dude
ULTIMATUC's Avatar
obviously, the diameter of the piping needs to be whatever YOUR inlet size is. just take your coupler with you if you're unsure.
post #3 of 12 Old 02-23-2006, 03:44 AM
DIY'er
Quoted: 4 Post(s)
iTrader: 3 reviews
Might want to pull your feed line and manually put some oil into there for this test too?? just in case???
https://www.nissanclub.com/forums/signaturepics/sigpic20104_1.gif
5 and a half inches of clearance w/ 1" wheel gap? Thank you 235/40/18's... Thank you.
Check out my blog!!
http://awdu13.wordpress.com
drunkmunky is offline
post #4 of 12 Old 02-23-2006, 03:57 AM
Another Boosted Altima
Thats it.
So where was your leak Brain......
Special-K
And the name is supposed to be vader3120. F*** IT!
1997 Altima KA24DE-T RIP
1991 SE-R SR20DE - For Sale
-Tranny Swap Done (JDM B13 VLSD & JGY LSD)
2004 Jetta 1.8T - Daily Driver
-FMIC, Turbo Inlet Pipe, 3" Turbo Back Exhaust
vaser3120 is offline
post #5 of 12 Old 02-23-2006, 04:03 AM Thread Starter
The Dude
ULTIMATUC's Avatar
prolly not going to help. its not spinning.
Originally Posted by vaser3120
Thats it.
it was a huge leak where the cold pipe meets the throttle body. I generally crank the hell out of my clamps, but i had the pipe in there crooked.
post #6 of 12 Old 02-23-2006, 04:15 AM
ahhh i c
Special-K
post #7 of 12 Old 02-23-2006, 05:44 PM
Shadetree Mechanic
This is a must have for any turbo guy. Here's another more in depth thread on the topic.
http://www.stealth316.com/2-pressuretester.htm
IBI Wide body and Greddy SP1 catback FS
1993 Altima SR20DET Many mods.
2001 Maxima SE 20th Anniv./Auto
2004 Ford F150 Lariat SCAB Flowmaster/BIG BFG's
jaltima is offline
post #8 of 12 Old 03-18-2006, 01:02 AM
Breu Meister
Quoted: 1 Post(s)
bump an old thread; good job... what clamps do you use?
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #9 of 12 Old 09-02-2007, 10:44 PM
bump a great thread, should be cleaned and sticky
Special-K
post #10 of 12 Old 10-18-2007, 02:38 PM
Clean And Sticky
Special-K
post #11 of 12 Old 10-18-2007, 03:55 PM
Positive Contact
Blacktop_Prefect's Avatar
^+1
The darkest side of humanity animated.
Blacktop_Prefect is offline
post #12 of 12 Old 12-13-2007, 11:59 AM
thanks for the advice, i will try that, i hope it works.
Sheet metal machinery - Suppliers of new and used sheet metal working machinery.
tina ryan is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Forced Induction Forum (Turbo, SC, Tuning)
You may post new threads
You may post replies
