200sx se-r turbo - Nissan Forums : Nissan Forum
post #1 of 15 Old 12-07-2014, 08:57 PM Thread Starter
Quoted: 2 Post(s)
200sx se-r turbo
I'm wanting to make 400 - 500 horsepower. About 25lbs. of boost. Should I use a t3/to turbo or a t4?
Brian Mccombs is offline
post #2 of 15 Old 12-07-2014, 08:59 PM Thread Starter
Quoted: 2 Post(s)
Damn phones... a t3/t4 turbo or a t4?
post #3 of 15 Old 12-07-2014, 09:30 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Well, what other mods do you have? I ask because if you dont have other mods to support your goals, a larger turbo wont get you there. Could you list all of your mods. As for your question....what AR trim are you looking at? Are you going ball bearing? Hey could you also post some pics. Would love to see your car.
4DZC is offline
post #4 of 15 Old 12-07-2014, 10:38 PM Thread Starter
Quoted: 2 Post(s)
The car is cornered in my garage because of the length of time it's taking me to finish my motor. I have cut 7.5lbs. off my crankshaft. I bored .25mm then honed it with a torque plate. I align honed the block after installing arp main studs. I also added the oil squirters under the pistons. As far as the cylinder head I oversized the valves, ported and polished it. I have bought stage 4 cower cams with .530 lift and 280° duration. I also bought aftermarket springs and titanium retainers. To go along with the cams I bought Tomei adjustable cam gears.
post #5 of 15 Old 12-07-2014, 10:40 PM Thread Starter
Quoted: 2 Post(s)
I'll post a pic of my crank tomorrow. And any other parts you want to see.
post #6 of 15 Old 12-07-2014, 10:52 PM Thread Starter
Quoted: 2 Post(s)
I forgot to add I am using mahle forged pistons 9.5 to 1 and Manley h - beam rods with arp rod bolts. Everything is 0 balanced and ready to go. I'm using the stock flywheel for rotating mass.
post #7 of 15 Old 12-07-2014, 10:56 PM Thread Starter
Quoted: 2 Post(s)
But as far as trim, any suggestions? T4?
post #8 of 15 Old 12-07-2014, 11:02 PM Thread Starter
Quoted: 2 Post(s)
The site won't post a picture of my head. If you go to ecu help I have a pic there
post #9 of 15 Old 12-07-2014, 11:26 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
wow, lots going on! As far as turbos, bro honestly you'll be able to make your goals with either the T3/T4 hybrid or the T4. As long as your able to flow enough air thru the engine youll be fine. What are you using for your intercooler? Fuel mods? I would tell you to look at the Borg Warner turbos.... maybe the S356. Bad assed turbo that will flow a TON of air. Take a look at their different AR trims. Mounting the turbo with a V band or what do you have in mind?
4DZC is offline
post #10 of 15 Old 12-07-2014, 11:33 PM Thread Starter
Quoted: 2 Post(s)
I have a stock Evo 9 intercooler. Looking at a jwt fuel rail and 750 cc injectors. Turbo?
post #11 of 15 Old 12-07-2014, 11:34 PM Thread Starter
Quoted: 2 Post(s)
To you have any suggestions on an exhaust manifold?
post #12 of 15 Old 12-08-2014, 01:51 AM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Maybe after I see your engine bay...Dont remember how it is setup. (space)
4DZC is offline
post #13 of 15 Old 12-08-2014, 02:16 AM Thread Starter
Quoted: 2 Post(s)
I can take a picture of the one I'm driving. I'm driving a car that's idintical to the one I'm building.
post #14 of 15 Old 12-08-2014, 02:20 AM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Yeah that'll be great!
4DZC is offline
post #15 of 15 Old 12-08-2014, 02:26 AM Thread Starter
Quoted: 2 Post(s)
Sweet I'll hit you back tomorrow.
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Forced Induction Forum (Turbo, SC, Tuning)
You may post new threads
You may post replies
