My Turbo Altima SER build - Nissan Forums : Nissan Forum
 14Likes
post #1 of 46 Old 06-06-2015, 05:03 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Talking My Turbo Altima SER build
After years of planning to build my car, I finally got around to actually finishing it.. No small project to say the least.
I decided to go with a completely custom setup. No shortcuts taken, built for reliability. Here's the current setup on the car. Car made 513whp and 434 wtq on 12lbs of boost. Car has the potential to be close to 650whp, but the trans is my limiting factor. Yes, It pulls hard.
Street teaser at not even half throttle : http://vid1253.photobucket.com/album...424_200317.mp4
Dyno vid : http://s1253.photobucket.com/user/05...tml?sort=3&o=1
Built 5at auto trans(getting swapped to 6 speed because i lost third gear already..)
Built 8.8:1 CR short block, Billet main girdle, ARP main, rod, and L19 head studs, revup oil pump
JWT S1 cams and valve springs
ID725 CC injectors
Aeromotive 340lph fuel pump
AAM stage 1 350z fuel return kit
AAM oil pan spacer
Uprev GT MAF
SSIM manifold
75mm BBTB kit
NWP spacer kit
NWP block off plate
GT3582r with tial 1.03 a/r v band housing
Dual tial 38mm MVS wastegates
HKS SSQV BOV
On to the pictures during the build. fabrication of the headers to the combination point for the feed pipe up to the turbo.
05NismoGirl and sprocketser like this.
05SickSer is offline
The Following User Says Thank You to 05SickSer For This Useful Post:
post #2 of 46 Old 06-06-2015, 05:04 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Turbo mounting
Downpipe, i went with an oval 3.5" downpipe for clearance. oval piping tucks up tighter then round piping, and 3" oval piping has a smaller overall area then 3" round does, so to even it out i want with 3.5".
sprocketser likes this.
post #3 of 46 Old 06-06-2015, 05:10 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Exhaust work, all 3 " stainless piping, back to the dual split of 2.5"
wastegate installed
twin gate setup installed, sorry its dirty it rained on the drive home
post #4 of 46 Old 06-06-2015, 05:12 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Intercooler/pump mounting. I went with a water to air setup instead of the air to air most people run. I chose this setup for a few different reasons. Water to air is much more efficient then air to air. Also space is an issue, so running water to air setup required no cutting my bumper support or anything. the piping is alot more simplistic as well with water to air, much shorter piping and less of a mess of piping.
post #5 of 46 Old 06-06-2015, 05:18 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
heat exchanger and trans cooler mocked up and installed
Water pump for water to air setup installed and hoses connected
reservoir for water to air setup
ignore my beat up bumper and plate lol..
post #6 of 46 Old 06-06-2015, 05:18 AM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
turbo drain line and oil/coolant lines connected to the turbo
charge piping support mount
finished product
dyno video since i know you want to hear it!
on the street after my base tune
post #7 of 46 Old 06-06-2015, 05:49 AM
alti03's Avatar
Quoted: 13 Post(s)
Sweet good job. Welcome to the boost life. A lot better build than mine.
alti03 is offline
post #8 of 46 Old 06-06-2015, 06:11 AM
zerolimit
Quoted: 28 Post(s)
sick
zerolimit4life is offline
post #9 of 46 Old 06-06-2015, 12:42 PM
Shaving My Shoulders
RIZAMAN's Avatar
Quoted: 280 Post(s)
That.is.bitchin.
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
Originally Posted by Penguinchit View Post
All you G owners suck balls.
RIZAMAN is offline
post #10 of 46 Old 06-06-2015, 01:57 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Release the kracken!!!! Aaron has DONE it! Flux capacitor and all. That thing is a bag, no a few bags of chips and then some. Beautiful work Aaron. Beautiful! Now blueprint it and sells a few kits and this will virtually have paid for itself. Good to hear from you after so long.
sprocketser and BPuff57 like this.
4DZC is offline
post #11 of 46 Old 06-06-2015, 03:04 PM
It's all Gravy, baby!
Sideways the Seven's Avatar
Quoted: 182 Post(s)
That is one of the most beautiful things I've ever seen!
Sideways the Seven is offline
post #12 of 46 Old 06-06-2015, 04:54 PM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Thanks man, you are the OG of boosted 3rd gens though. you need some of this water to air setup
Thanks Lawrence, long time no talk buddy. I emailed you a few times to see what was up but never got a response, figured you just hated me... I didnt do the fab work myself, i dont have the space or a lift or the skills to tig weld lol. maybe so day i will though
you sold your car didnt you? any news on how that beast is doing?
thanks man, some day you will get a ride in it!
post #13 of 46 Old 06-06-2015, 04:55 PM Thread Starter
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Originally Posted by RIZAMAN View Post
That.is.bitchin.
riza hows it been man. i see you have a G now, switched to the dark side
post #14 of 46 Old 06-06-2015, 04:55 PM
registered owner
oterop's Avatar
Quoted: 61 Post(s)
Well done! Looks like you pulled all the cats. Did you use O2 sims or disable the code in the ECU?
2006 SE-R/AT. Racingline FSB, Grounding kit, Nismo CAI, DW65c fuel pump, UpRev Osiris Tuner, Sachs SuperTouring struts/shocks, SL springs front/SER springs rear, Optima Battery relocation to trunk, 18" Maxima rims, DrawTite hitch, Yakima Highlite rack, Kumho LX Platinum, Custom foil+ensolite 1lb/sqft sound deadening, 40% 3M tint
What's playing on my Bose? Black Rebel Motorcycle Club - Love Burns
https://www.youtube.com/watch?v=KdF_4Glx52I
oterop is offline
post #15 of 46 Old 06-06-2015, 05:02 PM
Super Moderator
4DZC's Avatar
Quoted: 375 Post(s)
iTrader: 33 reviews
Lol, your email went to my junk filter...lmao...I fixed it...Stupid Google Chrome. Yeah sold it and bought it back. Demodded it except for visuals before the sale and now its back to near stock. Moved on to an RS5 but still love the SER. Kinda glad I got the oppportunity to get it back. Whether or not you did the fab work or not, YOU are responsible for THIS project, and we have mad respect for this WHOLE thing.
4DZC is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Forced Induction Forum (Turbo, SC, Tuning)
You may post new threads
You may post replies
