Transmission filter - Nissan Forums : Nissan Forum
 1Likes
  • 1 Post By amc49
post #1 of 3 Old 05-06-2019, 09:45 PM Thread Starter
Transmission filter
Hey guys I own a 2004 Nissan Maxima 3.5 SE with 112000 miles. I've changed all motor and transmission mounts, o2 sensors replaced spark plugs and coils replaced cv axles replaced oil and filter changed and now i want to service my transmission because i still feel a little hard shift from park to drive and while changing 1st or 2nd gear. I want to drain and change the fluid and filter Is this a good idea or should i just drain the fluid and refill?
2004maxima is offline
post #2 of 3 Old 05-07-2019, 07:20 AM
Quoted: 154 Post(s)
Check whatever mount is the one that restrains the engine/trans from rolling back and forth, commonly one low at the rear of trans. That bad could easily make your hard bump issues.
Penguinchit likes this.
amc49 is offline
post #3 of 3 Old 05-08-2019, 02:40 PM
Super Moderator
Penguinchit's Avatar
Quoted: 131 Post(s)
All Nissan recommends in that transmission is fluid change. Do this:
Don't flush it. Buy 11 quarts of Matic-D. Drain the fluid, put 3 quarts in, start the car, hold the brake, don't let go holding the brake, make sure you don't let go of the brake, I can't stress enough how important it is to not let go of the brake, shift into each drive, letting it sit there for a couple seconds, back to park, shut off the car. Drain the fluid. Refill with your remaining fluid.
That process moves the new fluid into the converter so you don't have to do the drain, fill, drive twice nonsense. It's faster and more cost effective.
You'll see some people say drain, fill, drive, drain, fill...That's stupid. It wastes your time and money and it doesn't get as much new fluid in as the above procedure.
05 3.5SE AT
Lightly modded
Penguinchit is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan Enthusiast General Forums > New Member Forum - Introduce Yourself!
You may post new threads
You may post replies
