Dog bone engine mount replacement - Nissan Forums : Nissan Forum
post #1 of 3 Old 12-26-2017, 09:09 PM Thread Starter
I was surprised to not find a thread about replacing engine mounts? My upper mount (dog bone) needs replacing. Shops quote $100 for part/ $200 for labor. The part is $25 bucks on amazon. Seems low but... Has anyone replaced the dog bone engine mount? Multiple reviews for the part online say it was easy to install. Well I've heard that before but I know its the easiest of them all. Can anyone point me to a thread that has the instructions on replacement or helpful tips before I get into something I shouldn't? I'm assuming once the old one is off I shouldn't move the vehicle until I get the new one mounted so I'm concerned about screwing this up or not having some special tool I won't discover until I'm well into the project. Any help is appreciated. (Again I searched using multiple phrases and couldn't find a thread addressing this common repair)
'09 Murano SL
Past
'05 Q45
'00 Sentra
'97 Altima
Service Manual:
http://www.nicoclub.com/FSM/Murano/2009/
Jwick is offline
post #2 of 3 Old 12-27-2017, 04:57 PM
d0ugmac1's Avatar
Quoted: 1152 Post(s)
Haven't done it yet myself, but I understand it's one of the easiest to replace. Isn't it just two bolts? If not, the Murano FSMs can be found by 'parent directorying' the Altima FSM link in my sig. The procedure will be there in engine mechanical section (EM).
/ Brake Job / RA 5% Discount
d0ugmac1 is online now
The Following User Says Thank You to d0ugmac1 For This Useful Post:
post #3 of 3 Old 12-27-2017, 07:48 PM Thread Starter
Thank you. As you state only two bolts. Found the FSM for my make/model and now have the torque specs which I always try to get right. There is an order to which bolts go in first and tighten. No special tools which is always good! Thanks for your reply.
'09 Murano SL
Past
'05 Q45
'00 Sentra
'97 Altima
Service Manual:
Jwick is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Murano Forum
You may post new threads
You may post replies
[IMG] code is Off
