front end shake - Nissan Forums : Nissan Forum
post #1 of 7 Old 03-30-2019, 01:38 AM Thread Starter
front end shake
the front ends shakes. Not all the time but a lot of time.
any guess as to what it could be?
daddymurano is offline
post #2 of 7 Old 03-30-2019, 01:01 PM
d0ugmac1's Avatar
Quoted: 1152 Post(s)
I asume the shaking is speed related...ie some speeds are worse than others? Is worse at low speed or high speed?
Anyone else drive the car? Do you remember any curb or pothole events of note? When was the last time your brakes were serviced?
Basically what I'm getting at are things like:
bent rim(s)
seized brakes (rotors not smooth on both sides)
worn suspension parts
/ Brake Job / RA 5% Discount
d0ugmac1 is offline
post #3 of 7 Old 04-04-2019, 02:41 AM
I would start with getting your wheels checked balanced...weights on your wheel MAY have just fallen off. Then if wheels are fine, I would move to checking for warped rotors, if fine, then check for torn/sloppy/bad ball joints or front suspension bushings.
the dreaded tensioner/VTC intake sprocket failure reeked its havok...she'll be back!
Losimus is offline
post #4 of 7 Old 04-05-2019, 01:51 AM Thread Starter
It seems like the cv joint on the passenger side if I had to guess. It only does it when you accelerate. Sometimes it doesn't do it at all. Smooth when you let off the gas.
The Murano is mine now. I traded one of my better rides to my daughter for the murano. I haven't tried to check underneath or done much driving due to the alternator is out again.
And yes, I know if the battery is low shifts and all kind of crap can happen.
I'll update what I find to be the problem.
post #5 of 7 Old 04-05-2019, 02:20 AM
normally on FWD (or the AWD version, which is based off of a FWD platform) cars a bad CV joint will click or pop when turning or on full turn. ANOTHER possibility could be bad wheel bearings in the hub, my Altima had a bad shake at certain speeds and would have a bad hum/drone and would clear up at higher speeds.
Losimus is offline
post #6 of 7 Old 04-05-2019, 06:56 AM
Quoted: 154 Post(s)
Make it do it then tag on the brake somewhat while holding gas on same amount and see if it stops or lowers, likely tie ends then.
amc49 is offline
post #7 of 7 Old 04-16-2019, 10:13 PM Thread Starter
Both side cv axles got replaced.
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > Nissan Murano Forum
You may post new threads
You may post replies
[IMG] code is Off
