Front Brake Install (3rd Gen) - Page 5 - Nissan Forums : Nissan Forum
post #61 of 118 Old 06-25-2009, 05:29 PM
Dr. Kenneth Noisewater
DJNocturnal's Avatar
great write up! I plan on swapping out my rotors & pads after the summer.
did you replace just the front rotors? which ones are using? I looked through the thread but didn't see you mention that. definitely want something that won't rust.
DJNocturnal is offline
post #62 of 118 Old 06-29-2009, 11:01 PM
I'm planning on inspecting my brakes this weekend.
Here are some questions I got:
1) How worn out should the pads be when replacing them?
2) How can you tell if the rotors are in need of a replacement (bad/warped)?
3) When tightening the bolts on the calipers, my torque wrench has a lowest torque of 30 ft*lbs, which is higher than the required amount for the caliper bracket (20-25 ft*lbs). Can I just make sure that it's very tight and not worry about the torque for these bolts? I bought the torque wrench for the lug nuts.
4) When bleeding brakes, how do I disconnect the brake cable? Do I bleed 1 side at a time? When you say 5-6 pumps, do you mean leaving one brake cable disconnected and leaving a bucket under it, and pressing the brake pedal in the car 5-6 times? If I were to bleed the brakes for all 4 of them, does this mean pumping 4* 5 times = 20 times? Is it very necessary to bleed the brakes?
Thanks for the advice!
mrlifeguard is offline
post #63 of 118 Old 06-29-2009, 11:41 PM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
1. i believe the wear indicators are set to squeak when there is about 3mm of brake material left on the nissan pads .
2. does your brake pedal pulsate when you are stopping ? is the rotor surface smooth or are there groves in them ?
3. just tighten the caliper slide bolts until they stop and then go another 1/8 turn .
4. it is not "necessary" to bleed your brakes but its good to do . if you are uncomfortable/have no clue on how to bleed brakes i suggest not doing it yourself . changing pads is easy , its 2 bolts and the pads can only go in one way , on the other hand bleeding your brakes wrong will cause them not to work properly or not at all .
if you have any other questions , feel free to ask .
jimnolimit is offline
post #64 of 118 Old 06-30-2009, 05:50 AM
Thanks for the quick reply.
What do you mean by pulsate? When I brake at very low speeds, it does make a bit of a noise. I can see lines on the rotors, like circular lines. Are those considered grooves?
post #65 of 118 Old 06-30-2009, 06:12 AM
You should torque the caliper bolts to around 25-30 ft. lbs. If you are going to change the rotors, then you will need to remove the caliper bracket which has (2) bigger bolts. They should be torque to 125-130 ft. lbs.
Pulsate means when you are braking, does the steering wheel shake back and forth rapidly?
bob1234 is offline
post #66 of 118 Old 06-30-2009, 01:01 PM
No it doesn't. Where did you get these specs? Is there like a link or is it in the manual?
Thanks!
post #67 of 118 Old 06-30-2009, 02:58 PM
Prepare to be VQmized
Ctrl-Altima-Del's Avatar
Thanks!
Max specs are 23ft-lbs for the pin bolts and 72ft-lbs for the bigger bracket bolts. The specs are in the service manuals
'14 Tundra DC SR5 TRD 5.7l Avg MPG 17.6MPG
Traded : '03 Altima 3.5SE MT Avg MPG 26.423mpg 325000KM
Ctrl-Altima-Del is offline
post #68 of 118 Old 06-30-2009, 08:25 PM
I don't like feel like going through all the pages now, I bet I am pretty accurate to the specs. I remember a month ago, I looked up the specs on the service manual online.
I actually tightened the caliper bolts to 25 and the caliper bracket bolts to 125. Now I am sure these bolts will never come off,unless you use a breaker bar and a cheater pipe.
I have had no problems so far and no noise at all.
P.S. I bought stock front rotors and 4 sets of pads from a dealer in CA for a good price.
bob1234 is offline
post #69 of 118 Old 07-18-2009, 02:02 AM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
bump to the top .
post #70 of 118 Old 08-08-2009, 08:14 PM
great writeup, jim. i changed my brake pads today and had no problems. one thing tho, does it really matter if the brake pads have shims? because my old break pads did not have it and neither does my new ones.
just make sure to wear a mask because you don't want to be breathing in the brake dust. sorry for hijacking, but here is a link for those who want to see a clip on "how to change brake pads": How to change the brake pads on a Nissan Altima - Video | Wonder How To
Performance: | AEM CAI | Magnaflow resonator-Stock pipes-Magnaflow 14862 muffler | XS Header
Cosmetics: | 35% tint | OEM sidesills | OEM splash guards | OEM Fogs | McCulloch 6k HIDS | Raptor 6k Fog HIDS | LEDS | BT footwell LED kit | BT underhood LED kit | SE-R tails | AT S2 grille | Debadged | Red calipers | DIY Blacked out headlights | RL BTD |
Wheels/Suspension: | 05/06 SE Alloys-Yoko Avid TRZ | RL FTSB | Stillen RSB | RL REL |
pbwillz is offline
post #71 of 118 Old 08-09-2009, 09:24 AM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
the shims help dampen sound , if your brakes are not making any noise , then you probably wont need them .
post #72 of 118 Old 08-18-2009, 05:21 AM
Slave to the Wife
doevil98's Avatar
have you tried Satisfied Pro Ceramic. in my opinion there the best with stock rotors. dont know about slotted.
I reject your reality and substitute my own
03 ALTIMA=POLISHED PEWTER
LIMO TINT=APC FOGS
DARK FORCE TECHNOLOGYS 3" COLDAIRINTAKE
MAGNAFLOW MUFFLER\TIP=SATISFIED CERAMIC PADS
30"MAGNAPACK=2.5" PIPING
SSAUTOCHROME XS HEADERS=CROSS DRILLED ROTORS. coming soon
MY RIDE
altimas.net
doevil98 is offline
post #73 of 118 Old 10-16-2009, 08:47 PM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
bump .
post #74 of 118 Old 12-26-2009, 09:13 PM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
bump .
post #75 of 118 Old 02-22-2010, 08:55 PM Thread Starter
2010 2.5s Sedan
jimnolimit's Avatar
Quoted: 1 Post(s)
bump to the front .
You may post new threads
You may post replies
