2010 Sentra SR - all wheel ABS? - Nissan Forums : Nissan Forum
post #1 of 3 Old 04-04-2019, 07:56 PM Thread Starter
My wife's 2010 Sentra SR (with "convenience package", if that matters) has a roaring sound on the passenger rear when driving, I suspect the wheel bearing/hub assembly needs to be replaced. It's a drum brake back there.
Anyone know if the 2010 Sentra SR has ABS in the rear? There are two different wheel hub/bearings, one for ABS and one for not-ABS, was unsure which to order.
Thanks!
lannister80 is offline
post #2 of 3 Old 04-04-2019, 08:27 PM
Quoted: 5 Post(s)
A quick way to know it would be to drive on a gravel road, or on a grass, or rainy empty parking lot and try the ABS. If you have plenty of space you can even turn the steering wheel while braking and if it drifts then you don't have ABS.
But wait for a brtter answer, maybe someone can provide a better and less risky advise
FX-32 is offline
post #3 of 3 Old 04-04-2019, 08:44 PM
d0ugmac1's Avatar
Quoted: 1154 Post(s)
Open your hood and follow the brake lines...if you see a large aluminum box with a bunch of steel brake lines connected to it you have ABS...it's 4 wheel or nothing.
No harm in getting the ABS version for a non ABS car.
Just be sure to get the right number of wheel studs...that car came with 4 and 5 stud rear hubs!
RockAuto has a closeout special for a rear SER hub for just over $40 be sure to save another 5% with my discount code here
/ Brake Job / RA 5% Discount
d0ugmac1 is online now
You may post new threads
You may post replies
