August '12 NOTM - Congratulations SurraTT! - Nissan Forums : Nissan Forum
View Poll Results: Vote for August NOTM!
Wade01 36 21.69%
Mack181 30 18.07%
monstarr 16 9.64%
SilVuR JAkul 39 23.49%
SurraTT 45 27.11%
Voters: 166. You may not vote on this poll
post #1 of 109 Old 08-01-2012, 09:54 AM Thread Starter
Quoted: 52 Post(s)
Welcome to NissanClub's newest Nissan of the Month contest! The 5 finalist listed below were picked at random from the previous Entry Thread. Please take your time and vote for the NissanClub member that you think deserves to be our latest Nissan of the Month winner. Don't forget to scroll down as the 5 finalist have the option to reply in this thread with more pictures and a list of mods in order to draw more votes.
** Do not create fake accounts for votes **
Admins see every vote and subsequently check if the user account is valid. Finalist that cheat (as well as members that help finalists cheat) will be BANNED from the website! Let's make this fair, honest and fun for everyone.
Members with a 0 post count have been restricted from voting. Please take a minute to review The Official Rules.
This months sponsor is Racingline Performance!
The NOTM winner will receive a prize pack from Racingline Performance.
Poll will close August 31, 2012
The 5 finalists are:
1. Wade01
2. Mack181
3. monstarr
4. SilVuR JAkul
5. SurraTT
** If you would like to enter your Nissan into next months contest, CLICK HERE for the ENTRY Thread **
CHiP is offline
post #2 of 109 Old 08-01-2012, 11:06 AM
I'm kind of surprised that my car made it, but it couldn't have come at a better time because August 11TH is my birthday.
I'll get some updated pics and a list of things Iv'e done to the car so far ASAP.
Good luck everyone!!!
Don't call your car a Special Edition and I won't call mine an SE.
My car is a Special Edition, and I have all the factory options and the badge on the trunk to prove it.
monstarr is offline
post #3 of 109 Old 08-01-2012, 11:45 AM
Wow first time entering and I made it!! time to do it big!
Mods:
S Mesh Grille // Shadow roof spoiler // KYB GR2 shocks and struts // Projector DEPO headlights // SE-B BLK & Clear tail lights // K&N CAI // Speedz Front Bumper // Performance Headers // MTX 2x 12's // Yellow LED Underglow // Much more and more to come...
BLACK & YELLOW!
Mack181 is offline
post #4 of 109 Old 08-01-2012, 02:21 PM
August '12 NOTM winner
Quoted: 2 Post(s)
the 5.7 Gen Maxima
This car is the very first of its kind. I took a 2002 Maxima (5.5Gen) and swapped in a 2009 Maxima (7th gen)VQ35 into the car which is now called the 5.7 Gen Maxima.
Its not a ordinary swap, the 09 VQ has VQ35HR heads and various improvements over the older FWD VQ's.
My good friend purchased a 09 Maxima a few years ago, the first thing I did was look under the hood. I said that's the motor Ill swap one day! In August 2010 my car developed a rod knock. So I parked it and started the planning of the swap. In May 2011 I had the 09 VQ and was in the process of swapping. It was not untill the end of July 2011 till it actually ran.
First run/drive
2002 Maxima w 2009 Maxima VQ35 engine swap first run- YouTube
This 09 VQ is far superior to the older VQ's With bolt ons and tuning this motor is capable of 300whp with STOCK cams.
Here is a nice dyno video of a earlier pull. 5.7 Gen Maxima Dyno 297 whp Dynojet - YouTube
Here is the full mod list:
Engine-
- 2009 Maxima VQ35
- 75 mm Throttle body
- Composite intake manifold (SSIM)
- 52 mm intake ports on heads
- 10.6:1 Compression
- 09 stock cams
- ARP rodbolts
- ACL Race bearings
- Cattman genIII headers
- Cattman 3" catback
- Removed stock oil warmer
- 380 cc DW Injectors
- 4” Intake Piping (no MAF)
- Velocity Stack
- 6" AEM Dryflow Filter
- 05 Sentra transmission
- 4.133 Final drive
- Fidanza flywheel
- Spec stage 3 clutch
- One piece SS clutch line
Engine Management-
- Haltech 350Z ECU
- VoltageDrop.net Plug and Play Haltech harness
- Haltech Dual channel Wideband
- Dual channel wb gauge
- Exhaust Valve Timing ran by Haltech only
Suspension-
- Tein SS coilovers
- Truax full subframe connectors
- Subframe collars
- Progress RSB
- ES SB bushings
- ES control arm bushing
- ES motor mounts
- Moog balljoints
- Moog Tierods
- Moog sway bar links
- NWP TQ link
- 350Z Rays Track 18” Wheels
- Drilled/Slotted rotors
- Stock brake calipers
Other-
- Power folding mirrors w/factory switch
- Kenwood DDX6019
Right before the first run!
2009 VQ35
WHP=301 with stock cams
2009 VQ engine Swap thread
336.270.9202 CALL/TXT
Need a Patch Harness or Plug and Play Haltech/UTEC/EMU Harness? www.VoltageDrop.net !
SurraTT is offline
post #5 of 109 Old 08-01-2012, 04:39 PM
Surratt!!!! Ftw!!!!
2002 Maxima SE 6-Speed:Custom Turbo Setup w/ PTE 6266 Dual BB Turbo/Turbosmart Hypergate 45 Wastegate/Turbosmart Supersonic BOV/TurboXS Manual Boost Controller/Spec Stage II Clutch/Fidanza Flywheel/Cattman Headers, Fast Cat and 3" Exhaust/NWP Spacers/Stillen UD Pulley/Haltech 350z Platinum Pro/Haltech Dual Wideband Controller/SFR IM w/ 09 Maxima TB
404Hp & 393Ft-lbs. @8psi
ranmas2004 is offline
post #6 of 109 Old 08-01-2012, 05:04 PM
ser06's Avatar
You've got my vote!
ser06 is offline
post #7 of 109 Old 08-01-2012, 06:24 PM
Quoted: 5 Post(s)
Glad I made it this month! Today is my exact 3yr anniversary with my coupe as well.
Mods;
Suspension;
Racing Line Strut bar
Racing Line rear sway bar
Racing Line front and rear endlinks
Racing Line traction bar kit
Racing Line short throw shifter
Racing Line lowering springs
Wheels;
Currently stock but hope to finish my new ones
Tires;
BFGoodrich g-Force Sport Comp-2 (225/55R16)
Engine;
Stock
Runs on Amsoil synthetic
Had intake on but removed it
Other;
WC Lathe Werks custom weighted shift knob
Hyper-White interior lights
Custom illuminated kick plates
Nismo Headrests
A little about my car. 2009 2.5 coupe 6spd, most of what I have done is to make it handle and drive so its largely suspension. I have a lot of projects that I have been pursuing but had to put off, but plan to try and finish two this month. Everything that has been done is done by myself as well. I am anal about keeping my car clean as well, I spend more time then anything else detailing her and last year I spent about 22hrs doing a detail lol! I was known as having the cleanest car on campus at college as well which I am proud of . I dont have a ton of mods, but I hope people vote for my coupe for how clean she looks!
I currently hold the stock 1/4 mile record for a 2.5 at 15.598 at 88.3mph as well on stock tires!
Pictures:
In progress projector retrofit;
Video of last year at the strip:
Back to back runs from earlier this spring, on snow tires.
Best of luck to everyone!!!
2009 Altima coupe 2.5 6spd; my babe!
Amsoil synthetics, LED lights, illuminated kickplates, WC Lathewerks shift knob, Racing Line STS/TB kit/strut bar/RSB/ front & rear end links/ first 4th gen 2.5 with racing Line springs, first 4th gen to swap 7th gen maxima brakes (on 16" wheels).
-Plans for now/future:restored old school wheels in progress/ quad projector retrofit in progress.
Best 1/4 mile; [email protected] factory stock to the tires.
DD/work ride; 2000 Nissan Xterra 4WD V6 5spd
-Damn thing has a taste for blood and all my time, bringing him back to life= taking my money
Wade01 is offline
post #8 of 109 Old 08-01-2012, 06:32 PM
BoSs DoN bIG WaVeY
eskalaid's Avatar
Quoted: 1 Post(s)
your doing a maxima engine swap wade?
eskalaid is offline
post #9 of 109 Old 08-01-2012, 06:39 PM
Quoted: 5 Post(s)
I think thats SurraTT . But I will be building the engine down the road, I have some crazy ideas lol !
Wade01 is offline
post #10 of 109 Old 08-01-2012, 08:34 PM
NOTM - Feb 2010
tl2k2max's Avatar
Quoted: 64 Post(s)
Wont vote till later, but im pretty sure the max is getting it with that sweet engine swap. Nice work man. +1 for originality.
sent from my evo on autoguide homos
AEM CAI / Aerospeed XCS / NWP Spacers / Custom Y-Pipe / Raactive CF Exhaust + 3 inch piping / 2*Timing Advance / S5 Grill / M3 Roof Spoiler / 6000k Low / 6000k Fog / Oznium Angel Eyes / Tein S-Tech / Racingline FSTB / Nismo-Rays A34 / 235/35/19 Dunlop SP Sport MAXX / RTP Rotors / PBR Pads / SS lines / Redline Tuning Quicklift / LED Lighting
2006 SER - SOLD
2013 EVO X GSR
tl2k2max is offline
post #11 of 109 Old 08-01-2012, 09:45 PM
BoSs DoN bIG WaVeY
eskalaid's Avatar
Quoted: 1 Post(s)
i only ask cause in you sig it says 7th gen maxima swap in progress(delayed)
eskalaid is offline
post #12 of 109 Old 08-01-2012, 09:47 PM
Quoted: 5 Post(s)
oh, thats the brake swap man!
Edit; I corrected it, thanks
Wade01 is offline
post #13 of 109 Old 08-01-2012, 10:16 PM
black2.5alti's Avatar
Surra got my vote!
2005 Nissan Altima 2.5s
black2.5alti is offline
post #14 of 109 Old 08-02-2012, 03:55 AM
Quoted: 1 Post(s)
Dang, i forgot to enter the thread!
Old Car.
Engine & Tuning: Weapon R Intake|OBX TB Spacer|OBX 4-2-1 header|DC EX5012 aka fart can
Brakes & Suspension: Racingline FSTB|SE-R RSB|Brakemotive D/S Rotors+Ceramic Pads|Tein-S Springs|KYB struts
Interior: LED Interior,license plate, trunk and footwell| Carbon Fiber vinyl wrapped panels| DIY Voltmeter|35% tint|
Exterior:V-leds 6000k HIDs| Halo projector fogs with 6000K HIDs| Duplicolor Caliper Paint(Red)|light Smoked Taillights|
To Do: KYB struts| 35% tint|
Audio: Dual XDMAR6720| Kenwood P709|Kenwood P6994
Summer mode: 18" 350z V2 rims
Winter mode: 16" stock steels with General Altimax Arctic
New car: 2010 Infiniti G37S Sedan 6MT
Tein-S lowering springs, Taketa Cold Air Intake, Invidia Q300 Catback, slotted rotors, 20" STR Racing 607 20x9 F/20x10.5 R
Tigerlui is offline
post #15 of 109 Old 08-02-2012, 10:31 AM
Originally Posted by ser06 View Post
You've got my vote!
@ser06
Thanks for the vote.
I'll have updated pics and a list of things done to the car so far by this weekend for sure.
My Altima (06 2.5 S Special Edition) is my every day driver, so I just need an hour or two of quality time with it to clean it up and take some new pics.
monstarr is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan Enthusiast General Forums > NissanClub's Nissan of the Month Forum
