NIStune related - need help - Nissan Forums : Nissan Forum
post #1 of 1 Old 12-20-2014, 02:57 PM Thread Starter
Adam
Alright, so after going in circles trying to tune my car with a NIStune ecu, I thought I'd consult the internet and see what you all had to say and see if anyone had a saved tune that I could bum. So here are the specs.
1995 S14:
- 99 silvia spec R SR20det w/ 6 speed
- NIStune type 4 board in ADM ECU w/ modified JDM wire harness
- Greddy Profec 2 spec b boost controller
- 555cc injectors
- Z32 MAF
- S15 stock turbo
- AEM wideband (runs crazy rich most of the time)
- anything else relevent?
Anywho. The thing runs rich (as previously stated). It usually hits the 11's and then drops into the 10's and below at 25% throttle or higher. If I'm cruising, it's usually in the 13-14 range and it'll occasionally jump into the red when giving it throttle from a dead stop. I also get a hickup at around 4k and occasionally it'll misfire past 4k at wide open. But I'm getting into too much detail here. Does anyone have a similar setup with a saved nistune doc. that runs well?
adub1992 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN 240SX / SILVIA FORUMS > SR20DET Engine Discussion
You may post new threads
You may post replies
