Altima SR 2016 - LED appearance - fog lights? - Nissan Forums : Nissan Forum
 2Likes
  • 1 Post By betonven
  • 1 Post By Newalt08
post #1 of 12 Old 06-26-2016, 03:36 PM Thread Starter
Quoted: 3 Post(s)
Hi guys!
I recently got my new Altima 2.5 SR, including the LED appearance pack. I really like the white color of the low beam headlights (reason I agreed to pay more for the LED package), however I noticed that the fog lights are still yellow, which makes the front appearance of the car when they are both turned on kind of...weird.
I'm kind of surprised Nissan allowed this to happen to one of their non-base models, especially when making you pay an overpriced fee for the LED pack. So, two questions:
1. Is that normal? (Or something weird happened to my car - manufacturing error or something)
2. Is that fixable somehow? (replacing the fog lights with white colored)
Thanks in advance!
Novia likes this.
betonven is offline
post #2 of 12 Old 07-01-2016, 12:04 AM
Newalt08's Avatar
Quoted: 14 Post(s)
Here ya go, friend. https://www.theretrofitsource.com/co...l#.V3WzQpMrJBw
I also hear Nissan sells a LED fog light upgrade kit as an accessory.
Jscpuma08 likes this.
Newalt08 is offline
The Following User Says Thank You to Newalt08 For This Useful Post:
post #3 of 12 Old 07-03-2016, 10:24 PM Thread Starter
Quoted: 3 Post(s)
I see.... you're right, I just found the upgrade kit in Nissan's website. I think it's really ridiculous for them to charge you for 600$ the LED appearance pack and not include fog lights.
...in any case... since the price on the link above is similar to the price of the Nissan pack... what would it be best for me? (I have minimum to zero experience in installing these things on my own, but if there's a detailed manual, I'm willing to try).
(I also have a very bad experience from dealer installed third party xenon lights in a Ford Focus I had in the past... They kept turning on and off for no apparent reason, some times I had to drive in complete dark conditions.. but no idea what brand it was... probably the cheapest they could get in their hands to claim that they give "free xenon upgrade"
betonven is offline
post #4 of 12 Old 07-03-2016, 10:27 PM
Newalt08's Avatar
Quoted: 14 Post(s)
They are literally plug and play. Just remove the old one, and plug in the new ones. I'd go with the Morimoto units since they are $20 cheaper. But that's all up to you. Each dealer sets the price of their parts, so you could call around from dealer to dealer.
Newalt08 is offline
post #5 of 12 Old 07-03-2016, 10:42 PM
Newalt08's Avatar
Quoted: 14 Post(s)
Here's the downloadable/printable PDF to add fog lights. Since you already have them from the factory, you just need to to the opposite of the installation of the assemblies. It's very easy. I've installed these exact lights on my 2015.
PDF: http://www.nissan-techinfo.com/asist.../T/Q/1TQ40.PDF
Newalt08 is offline
post #6 of 12 Old 07-08-2016, 03:51 PM Thread Starter
Quoted: 3 Post(s)
That was very helpful. So, if I got it correctly, all I have to do is change the existing fixtures with the new ones? I don't have to change any power cables etc.?
Also, something very important: Does any of you have some specs about the OEM LED low-beam headlights my car has? I would like the color temperature and the intensity of the fog lights to match that, otherwise there is no other point of making the upgrade!
betonven is offline
post #7 of 12 Old 07-09-2016, 07:37 AM
Newalt08's Avatar
Quoted: 14 Post(s)
I want to say all color temps of OEM LED lights are the same because they need to meet certain DOT requirements. The fog lights I have would match perfectly with the color of your OEM LED headlamps
Newalt08 is offline
post #8 of 12 Old 09-02-2016, 04:53 PM
Newalt08's Avatar
Quoted: 14 Post(s)
I just received my replacement car from the DC Lemon law procedure, and I opted to install my TRS LED fogs I had on my 2015. They are a great match for the LED headlights on the 2016 3.5SL
https://goo.gl/photos/LwnMy6RaGtEB4E9dA
Newalt08 is offline
post #9 of 12 Old 08-01-2018, 12:43 AM
Does your car have LED low and or high beams betoven and or Newalot08. The reason I ask is because I am considering installing these in my car and want to know if it should be a plug and play swamp.
Halo9809 is offline
post #10 of 12 Old 08-01-2018, 01:48 AM
Newalt08's Avatar
Quoted: 14 Post(s)
Low beam only in the factory LED housings. I have a buddy who installed them on his 2.5 S model. They do not plug and play. You'll need a harness, and will need to add a relay so the DTRL lights will work. But as is, they will not plug up to the existing wiring harness of the vehicle.
Newalt08 is offline
post #11 of 12 Old 08-01-2018, 02:35 AM
Yeah thats exactly what I want to do to my SR. I am curious if you would be able to find out where he got all the hardware you speak of though like the harnesses. I wouldn't necessarily need the LED DRL'S if a relay is needed, especially if it involves splicing or cutting :X I am more of an adapters type of guy.
Halo9809 is offline
post #12 of 12 Old 08-01-2018, 10:50 PM
Newalt08's Avatar
Quoted: 14 Post(s)
Well, you would need the relay or the lights would run 24/7, and at full brightness. The harness can be had at the dealer. You'd just need to unplug the existing harness and plug in the new one. But the relays are a MUST. The factory OEM DTRL's already have a relay installed.
Newalt08 is offline
