Reset AWD light - Nissan Forums : Nissan Forum
post #1 of 3 Old 02-03-2018, 12:37 PM Thread Starter
Robert Godwin's Avatar
Quoted: 2 Post(s)
Reset AWD light
I have 2014 Rogue Select and the AWD light stays on constantly and will not turn off. How do I go about resetting it? I have taken it to my mechanic and he has cleared all codes and nothing shows up after he ran a scan
Thanks for any help
Robert Godwin is offline
post #2 of 3 Old 02-03-2018, 03:50 PM
rogoman's Avatar
Quoted: 23 Post(s)
There's an AWD control unit that's located on the back side of the body panel in the luggage compartment. You'll have to remove the luggage side lower finisher (LH) to access it. Check the harness connector by reseating it; the pins may have some oxidation on them. If that doesn't fix it, the unit may be defective.
There is a procedure for testing the AWD control unit that's described in the FSM. You can download a PDF copy from:
Nissan Rogue Service Repair Manuals
KA-T for life, yo!
rogoman is offline
post #3 of 3 Old 02-22-2018, 01:45 AM Thread Starter
Quoted: 2 Post(s)
I have looked all through the PDF that you sent me but there is nothing about resetting the AWD Is there something else I can do it is becoming very annoying.
Thanks
You may post new threads
You may post replies
