One DRL off after low beam LED install - Nissan Forums : Nissan Forum
post #1 of 1 Old 07-28-2018, 04:04 PM Thread Starter
Ello,
I installed aftermarket low beam LEDs on my 2015 Altima 2.5S and now my driver side DRL is completely off. It works as a turn signal regardless of the low beams being on or off. I have changed the bulb multiple times but I know the bulb is not the issue.
I contacted the seller and was sent a pair of relays. I installed them bu the problem persists. The seller is unsure of what to do next and is offering a replacement set of low beams or a refund, I just wanted the damn DRL to work.
For reference, the passenger side DRL works as normal (on with the low beams, and as turn signals)
Any ideas?
PS I searched the forums and read quite a few posts with LED and DRL topics but none that was the same as mine.
Thank you
davidccs is offline
You may post new threads
You may post replies
