in-dash turn signal bulbs - Nissan Forums : Nissan Forum
post #1 of 1 Old 11-05-2018, 03:55 AM Thread Starter
Good Evening,
2001 altima and I changed the backlights in the dash to led white. Also changed all exterior bulbs to leds. I then changed the turn signal relay to one that is specifically for led's. Since then the green turn indicator lights in the dash do not light. Turn signals/and relay work fine without hyper-flash it's just the silly green lights won't light up. When I pulled the Backlights I did not see separate bulbs for any of the indicators on the back ie; oil, fuel low. Is there a way to check, fix or replace them that anyone has discovered before. Thank you so much for any information you may have.
2001 GXE is offline
You may post new threads
You may post replies
