1 - 6 of 6 Posts
Hello I was having problems with the rpm being above 1000x I got it checked and the sensor connected to the throttle body was bad, I replaced the throttle body and the idle is normal and it revs good, but now I have 4 codes, p1122, p0123, p0223 i forgot the last code... Is there something I need to do or do I just erase the codes???
You can try to erase the code and do all of the relearn procedures. If nothing works you will have to swap out the throttle body. When I had throttle body issues I recall having similar codes and they only went away after I swapped for a different throttle body. If it turns out that you do need a tb then you have a few vehicles to choose from at the junkyard ( 2003- 2008 Infiniti Fx35 & M35 / 2003-2006 G35 & 350z / 2002 - 2004 I35 / 2003-2009 Murano / 2004-2009 Quest / 2002- 2008 Maxima). I am currently running one off of a quest with no issues. gl
Start The Show - Jet
^^ good question, also I assumed that the op had a v6 but if it's not then forget everything I said :).
Most of what you said is still right, but applies to the QR25DE motors. Sentra, Rogue, etc. use the same motor, so you could look for those, too. Here's a link to the QR info.
Discussion Starter · #6 ·
I did the idle relearn procedure and erased the codes, for now it's good... But now I have 2 codes for "knock sensor bank 1 lean" any ideas??? I just got the knock sensor replaced...
1 - 6 of 6 Posts
