1 - 3 of 3 Posts
06 altmims wont start. Help what could it be?
First thing to do is check to see if there are any codes stored. If so, that will give you place to start and some ideas of what the problem may be. If there are no codes it's time to start troubleshooting. Three things are needed to make an engine run fuel/fire/compression. Once you find out which one is missing it will be easier to figure out the problem.
A good beginning would be to not act like words cost you $5 each and add more detail to your post. Like does the car even have an engine in it; not having one means it won't start. Get what I'm hinting at here?
You will only get back what you put in, we can't work on the car more than you. For free while we're at it. We expect a certain amount of personal input from owners, simply saying my car is broke please fix it is not enough for us to write a 500 page book and you are there.
1 - 3 of 3 Posts
