1 - 4 of 4 Posts
just got a 07 3.5. had a issue with the gauge not returning to cold when shut off/no power showing warm when not running. replaced the temp sending unit and it was fine for a few days then this morning it read hot again i hooked up my scanner and on the scanner it showed 198. Do you guys think it could be a gauge issue? Really puzzled by this i've never run into this before
It is odd...how clean was the connector/wire at the sensor? any signs of cracks or corrosion?
thanks for the update.
1 - 4 of 4 Posts
