1 - 2 of 2 Posts
Sorry if this is the wrong spot but I didn't see a forum for Rogues.
The Heat and AC work but the fan stopped working. It was high or nothing for a bit, then only nothing.
Replaced 2 blown 15Amp fuses and it worked again, for a few days. Fuses have not blown this time.
Replaced Blower Motor resistor, still nothing.
Is there a way to check the blower motor without taking it out? It does not look like an easy job.
Discussion Starter · #2 ·
UPDATE: Fixed.
The Blower Motor was drawing too much current because it was failing which caused the resistor and fuses to fail. I replaced the failed resister and fuses first but still had a bad motor. After the new motor was installed i also replaced the resistor again and all is well.
1 - 2 of 2 Posts
