1 - 3 of 3 Posts
· Registered
I put a blower motor on the car which means the pedal assembly had to come out after i put it back together its as if the brakes are locked up and the brake pedal is not moving any and all suggestions would help
· Registered
Hi there, I suppose there's something wrong during the process of your 'put it back together'. But still, you can check the most common causes of locked-up brakes: an overheated braking system, using the wrong brake fluid, damaged or broken parts (calipers, brake pads, pistons, rotors, or others), a defective ABS component, broken parking brake, and more.
1 - 3 of 3 Posts
